Broke the truck again #385698
07/25/09 09:08 AM
07/25/09 09:08 AM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
My son and I took my pile of scrap to the track for T-n-T yesterday. I wanted to try and get the home made caltracks and ranchos dialed in along with dialing in the carbs. First pass I set the shocks on 7 and ran 12.5 lbs. in the slicks. It spun a little coming off the line but went straight, carbs were real lean. Went back to the pits set the shocks on 9, went down to 12 lbs. on the tires. Went down .010 on the air bleeds on the secondaries and closed the air doors down about .250. Truck still spun a bit off the line but left straight with very little weight transfer. It was still a bit lean. Back to the pits, went up 4 more jet sizes on the rear, up 2 in the front, went back up on the air bleeds, opened the air doors up again. Went with 13lbs. in the slicks as at 12 the ride was REAL unstable down track at speed. Motor was still real lean and poped and missed on this pass. Back at the pits I put the small bleeds back in and closed the air doors down again. 13 lbs. in the slicks, back at the line I brought the motor up against the converter, at the last amber I nailed it. It went instantly into wheel hop, it bounced the rear tires off the ground 3 times before I could get off the throttle. I think the front tires even bounced off the ground. I now know what a paint can feels like in a paint shaker.
The end result of all this was the motor moved forward and the fan and brand new aluminum radiator are history. I first thought I'd broken a motor mount or something. After looking everything over thought everything appears to be intact and where it belongs. I guess I'll be making up a couple fore and aft engine limiters.
From viewing my sons video what I came away with was, I need more tire under the rear and possibly some new leaf springs. The shocks were almost all topped out on launch. So, I'm done for the year now, frustrated, but know which direction I need to go. Dave
Re: Broke the truck again [Re: quickd100] #385699
07/25/09 12:03 PM
07/25/09 12:03 PM
WA 98043
thecarfarmer Offline
WA 98043
Dang, Dave, I'm really sorry to hear that!
My truck looks up to yours as a big sister...
Maybe your shocks topping out was the cause of the problem?
Glad you didn't lose control and wreck the truck.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Broke the truck again [Re: thecarfarmer] #385700
07/25/09 08:07 PM
07/25/09 08:07 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
Hate to hear of the carnage Dave, keep after it.
Finding the weak links sucks, done a lot of it.
Re: Broke the truck again [Re: RedRam] #385701
07/28/09 08:26 PM
07/28/09 08:26 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Sorry to hear that Dave; I thought this would be the year that the truck would lay down some good numbers. I guess the next time I see you, you will be wearing a cowboy hat and playing the part trying to tame that Wild Hemi Stallion of yours.
Re: Broke the truck again [Re: Hemi_Ram] #385702
07/28/09 10:21 PM
07/28/09 10:21 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
You didn't have them?? Is it a motor plate or stock mounts? Could be a number of reasons why it wasn't hooking. I'd look at tires last...
Re: Broke the truck again [Re: Kevins493] #385703
07/29/09 06:08 AM
07/29/09 06:08 AM
nielsville, minn.
Q
Q
nielsville, minn.
There are no such animal as stock mounts for a hemi in a 1960 D100. The mounts I've made are much stiffer than any factory stuff and I also have a turnbuckle on the front drivers side just in case. I would have said it's not possible for what happened to happen but it did.
The slicks are old and to small. With a lot less horsepower this thing used to pick the front tires up and run some really impressive 60 ft. numbers for what it was. From looking at the tape the rear springs are past the limit of what they can control. I'm suprised they worked as well as they did for so long. They're only 50 years old now. Dave
