Re: Engine break-in with coated headers?
[Re: 300by500]
#385524
07/25/09 12:06 AM
07/25/09 12:06 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Wouldn't be a bad idea to borrow some headers if you can.
[Re: 300by500]
#385525
07/25/09 12:07 AM
07/25/09 12:07 AM
Posts: 4,086 The Wet Coast, Canada
megajoltman
Burnt mine really good on the dyno till I had the tune right.Glad they were just painted I would try and find some others to use JM
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: 300by500]
#385530
07/25/09 07:21 AM
07/25/09 07:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Was the carb run before, it should be close... most of the time its the timing isnt right during break in... get the timing right first thing
[Re: MR_P_BODY]
#385531
07/25/09 08:05 AM
07/25/09 08:05 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Here's a trick to get the timing correct before you fire it. Take all the plugs out, put them in the wires and lay them on the headers. Then you can crank it over with a timing light and check it before you attempt to fire it.
[Re: Bigcube]
#385532
07/25/09 08:15 AM
07/25/09 08:15 AM
MR_P_BODY
Jim all I do is set the crank at X degrees before then set the leading edge of the rotor to the cap terminal But most guys dont realize that at 2000 rpm and no load it should be more advance than the load type timing
[Re: MR_P_BODY]
#385533
07/25/09 08:20 AM
07/25/09 08:20 AM
Bigcube
Upstate NY
With a crank trigger I can't change it once the car is running. Because of that I get it set with a light before I attempt to start it.
