Best year CTD #385406
07/24/09 09:23 PM
07/24/09 09:23 PM
templeton,ma
coro500net Offline OP
templeton,ma
Looking for a used 2500 CTD and was wondering if any years are better than others.Looking for info
on complete truck(auto trans,manual trans,brakes,suspension,and so on)
Re: Best year CTD [Re: coro500net] #385407
07/24/09 11:58 PM
07/24/09 11:58 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I've had my 2001 2500 with a Cummins and six speed stick for 9 years and it's been great. Bullet proof, still starts and runs like new, no squeaks, no rattles. Only issue is the air doesn't blow real cold anymore, I have to have it checked.
The HO motor and the six speed really make for a great tow or camper truck. It's also fun to row through the gears with 500+ ft/lbs on tap for day to day driving. You start in second unless you're towing so it's like having a five speed. I don't have a cat, so I can do any power adder mods or exhaust I want and still be legal. The 2001 and later have better brakes imo. Late 2001 and later have four wheel disc brakes.
I bought the six speed because it a very heavy duty trans. The transfer case is a 241HD with a Dana 80 rear diff and Dana 60 front diff. The regular cab models have a one piece drive shaft, no center support bearing which is a good thing imo.
The only way I'd buy an automatic is if it already had an after market built heavy duty trans and converter or be ready to spend the $3500 or so to upgrade a stocker. That's just my opinion, I have no experience with the stock auto trans, but I've heard enough about them to figure it's a "gotta have" mod on an automatic equipped truck.
Steering wander is a big issue on the 4x4s. I found it's because of the tires. I had 305/70/16 Pro Comps and it was rock steady steering. I replaced them with 295/75/16 Nittos and the sucker wanderd alot until I got used to it. I would not put any tire on one that has a larger than 70 aspect ratio.
Patriot blue with Skyjacker suspension...
Re: Best year CTD [Re: coro500net] #385408
07/25/09 12:12 AM
07/25/09 12:12 AM
Nebraska
FASTBACK66 Offline
mopar addict
FASTBACK66  Offline
mopar addict
Nebraska
I prefer the first gens. 89-93.89-90.5 are non Intercooled so that might sell cheaper. I also prefer the 12 valves for ease of upkeep/repair. They can be had up to 98 mid year or so. If your really lucky, you can find a 98 12V with the quad cab (first year is 98).The automatic first gens are slouches. Converters are junk. A good aftermarket one is about $600-$750 from DTT or Goerend. The manual ones ,NV4500 beats out the Getrag in strength if your going to tune it up or heavy tow.The 2nd gens 98-02ish are decent 24Valves. Way easy to get hidin HP from a programmer/tuner (Bullydog and such) but some people tend to dislike the commonrail fuel system around here. Not sure why. Not sure of the first year for it but a manual six speed NV5600 came with them too.
The first gens can be had cheaper (usually) but I've seen them bring big bucks too. Depends on which body style you prefer. I have never driven one with really great brakes. Only good, mediocre braking. If you go first gen. Watch for the KDP (Killer Dowel Pin). It's behind the timing case and quite involved to fix. Also check the IP (Injection Pump) and look to see if the tamper proof caps are still in place. If so, nobodys turned it up. Minimal time and money invested on a 12V can gain alot of hidin power. My
Vinny
Re: Best year CTD [Re: FASTBACK66] #385409
07/25/09 12:42 PM
07/25/09 12:42 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Go to bluechipdiesel.com to read a little on the Bosch VP-44 "injector pump of doom"
The pre 2003s back to 98,5 were real good trucks with this exception.Also the 5 speeds have a bad rep for taking themselves apart if you lug them.
My die hard Guru did all kinds of terrible and wonderful things to his 2002 for many years and recently got a 2006 3500 6 speed, LOVES IT! Says hes getting 25 MPG w/90 horse injectors.Also, conventional wisdom locally says an auto just will not live behind these motors, I advise to not buy an auto at all.
Luck, C
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: Best year CTD [Re: Sixgun] #385410
07/25/09 12:59 PM
07/25/09 12:59 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I've got an 04.5 with an automatic. It's got 197,000 miles and most of that was pulling a car trailer. It is by far the best truck I have ever owned and I'm not afraid of the automatic even though I've heard the stories. I know another 06 with an automatic that pulled a two car trailer professionally that lasted almost 300,000 miles. My only issue with this truck is the cost of the injectors. They are crazy expensive compared to earlier models. I'll stick to the 03-up trucks for comfort, braking, power, and generally low maintenance.
Re: Best year CTD [Re: AeroMonte] #385411
07/25/09 09:25 PM
07/25/09 09:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I've got a 2000 with an AUTO , 212k miles , 120k on the trans since a rebuild and the wound on the trans was self inflicted , the VP FINALLY died ata 212k , the low sulphur fuel and a lift pump putting out only 5psi were it's DEMISE , 416HP at the rear wheels , ran it out of fuel more times than I care to admit , drove it for weeks with an inop lift pump ...
don't believe everything you read on the internet .
Re: Best year CTD [Re: Sixgun] #385412
07/25/09 09:34 PM
07/25/09 09:34 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Luck, C
I have a 2005 6 speed and love the truck I would like to know how someone is getting 25 mpg through if I really try hard I can manage 18-19 empty but you have to work real hard to do it I think 18 is good for this big of truck but that's a long way from 25.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
