Elevation VS Compression ratio ??? #385185
07/24/09 03:25 PM
07/24/09 03:25 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
How much more compression do you need (or can you run) VS how high you are asumeing you fix your jetting for the change so the elevation is the only real differance? Same octane fuel of course.
Re: Elevation VS Compression ratio ??? [Re: HotRodDave] #385186
07/24/09 03:51 PM
07/24/09 03:51 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
multiply by 10s for 1000 ft
5373207-Compvspower.xls (80 downloads)
Re: Elevation VS Compression ratio ??? [Re: HotRodDave] #385187
07/24/09 04:03 PM
07/24/09 04:03 PM
organ
maximum entropy Offline
organ
up here in central oregon (3600 ft) i add about a half point or so. i reckon there's prolly a formula, but i don't recall seeing one. i'm thinkin' it would be a simple matter of determining your air pressure. we average ~9% less dense than sea level.
Re: Elevation VS Compression ratio ??? [Re: HotRodDave] #385188
07/24/09 04:46 PM
07/24/09 04:46 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
I would think that the cam would make a bigger impact, a later closing point. Cyl. pressure, Over static comp.
Re: Elevation VS Compression ratio ??? [Re: moparlulu] #385189
07/24/09 05:14 PM
07/24/09 05:14 PM
CA
62SAVOY Offline
62SAVOY  Offline
CA
http://www.rbracing-rsr.com/compression.htm
Try this and just input 0 for the PSI number. It will show you what happens at different altitudes.
Re: Elevation VS Compression ratio ??? [Re: 62SAVOY] #385190
07/24/09 11:43 PM
07/24/09 11:43 PM
Kalispell Mt.
Kalispell Mt.
Thats a handy calculator
My 11.5 is going to be about 10.9 at my 3000ft altitude
Re: Elevation VS Compression ratio ??? [Re: HotRodDave] #385191
07/25/09 02:51 AM
07/25/09 02:51 AM
CA
62SAVOY Offline
62SAVOY  Offline
CA
It worked good for me figuring what to do with my blower at the elevation I am at.
Re: Elevation VS Compression ratio ??? [Re: 62SAVOY] #385192
07/25/09 05:14 AM
07/25/09 05:14 AM
Utah
topbrent Offline
topbrent  Offline
Utah
For some brain exercise, this is a good study on the effects of elevation.
Intended application of this report was for aircraft, but there is good applicable info.
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19930091074_1993091074.pdf
