Re: Can I do a re-ring in my garage?
[Re: DaytonaTurbo]
#385138
07/24/09 02:43 PM
07/24/09 02:43 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I did it. But you need more than basic tools. Engine hoist/cherry picker, torq wrench, cylinder hone/deglazer, piston ring compressor. Then while you're at it you'll want a decent valve spring comrpessor to do the heads.
Also, see my response in your other thread.
Hopefully you are planning to pull the engine to do it. It won't take very much if any longer. In fact I would venture quicker and much more efficient. While you are at it plan on having the crank checked and new (at least) rod bearings.
[Re: cudabitten]
#385142
07/24/09 05:31 PM
07/24/09 05:31 PM
Heck yeah!
Don't be afraid of a few specialty tools that aren't all that expensive!
I started out doing a wore out 318 that really should've been bored but worked anyway. Had lots of fun beating on it for not much $$$.
I've since come across 2 really nice 440's that only needed a re-ring and bearing kits to be perfect again. I've done everything save for the valve job/hot tank/resurfacing in my garage.
It's a great learning experience!
#385144
07/25/09 12:09 AM
07/25/09 12:09 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
pop the oil pan, remove intake and heads (probably the hardest thing of all) remove rod caps one at a time and use the wooden handle of a hammer to push the piston out. break glaze with a honer (ballz or stones) wipe clean, rering and drop 'em in with a compressor and rubber tubing over the rod bolts so as to not scratch the crank. check bearings while you are down there, cheap insurance. Torque them down, replace top end and break in per manufacturer. Solid 3 night job and your nails will be dirty for a while. Impact gun is [Edited by Moparts - Family Friendly Site - Keep it clean] for breaking head and rod bolts, will cut 1 hour off your time and lots of sweat. I did a crank too without even removing the trans or heads(auto), trick is to remove spark plugs...
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
