Re: Are 3.91's enough gear?
[Re: Dougsmopars]
#384937
07/24/09 05:27 PM
07/24/09 05:27 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Your approach is similar to repairing a hole in a dam by adding berms to direct the flooding better... The issue is the cam is wrong. The 484 sounds small, but it has big duration numbers for its size and the rest of the engine can't support it. Therefore it can't support the car. You are looking at hundreds for a gear and convertor swap, or either by itself... Why not spend a few hundred on the right cam? If it's too much for you to handle, find a reputable shop to do it for you. You'll be much happier. It's a dog down low. It's still a dog when you rev because of the manifolds and the lack of compression. So instead of making it a dog you're going to try to minimize the dogginess? So what's the real reason your fear changing the cam? Is it an engine warranty issue or something? The package is perfect for what you do except for the cam. $300 in parts, maybe $400 in labor to pay a shop, and it's fixed permanently. $700 is a little more than buying a used chuck and installing it yourself, and a lot less than buying a convertor with that rear and installing both or having them installed.
[Re: Dougsmopars]
#384938
07/24/09 05:55 PM
07/24/09 05:55 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
That cam isn't that radical. I agree with previous that you should check cam timing. A good 2800-3000 stall should be plenty in a 440. Is your intake a dual plane? If not lose it and get a dual plane. Remember basically stock 440's don't make power over 5000-5500. There torque monsters down low. A bone stock 440 with 3;23's should roast the tires off.
The cam is ALL wrong. He'd be better off w/ a stock 440 cam than that 484. It is a bracket racing cam. It needs 10:1+ 3000+ stall 3.91's or better, intake, headers and the rest to work. Trust me a stockish 440 w/ 3.55's and that cam will net you a slow, non tire spinning B-body.
[Re: demon440]
#384941
07/24/09 10:11 PM
07/24/09 10:11 PM
Posts: 4,930 Tri-Cities, Washington
VITC_GTX
I think you should finish one car before you tear apart another. Don't you have 2 or 3 projects going on right now? Or you could sell me your Demon.
Oh, that hurt
Yeah, I have two in bare metal and one in primer...
[Re: jbc426]
#384942
07/24/09 10:15 PM
07/24/09 10:15 PM
VITC_GTX
What is your compression ratio? If your tune is good, the right converter and cam will do wonders with 3.54's.
What do you have the timing set at, initial and total? What do your plugs look like? You can easily change the cam and lifters with the motor in the car without removing the intake. You can always contact Dave over at Hughes Engines and talk to him about your set-up and see what he recommends.
Compression is stock (advertised 10.0:1) with the heads shaved .030". Not sure what actual would be...
I think timing is ~18 initial 35 total (or close to it) on FBO advise.
[Re: Mr.Yuck]
#384943
07/24/09 10:20 PM
07/24/09 10:20 PM
VITC_GTX
284/484 MP cam <--- that be your problem... and if you have a carterbrock carb. 3.91's and more conver will help. or you can swap the cam out for something a more street friendly. I'd do the cam...much easier and cheaper.
I guess everyone's different but I would rather change a converter and rear end than a cam.
I hate cracking the motor open (nicely painted, etc) and I love the lope of the cam. The sound is the best part of the car.
[Re: VITC_GTX]
#384947
07/24/09 11:26 PM
07/24/09 11:26 PM
Posts: 4,884 Michigan
MNobody
You could also get a shorter tire 26" a 275/50/15 They are a little wider i think about a 1 inch off the top of my head.
it would be a real easy way to see how your car likes a higher gear and free if you could borrow a set.
a 26" tire on a B-body would look silllllllly.
But it would be a good way to see how it would run with lower gears.
I had l-60-14's on my 69 Charger, it didn't look bad
[Re: VITC_GTX]
#384948
07/25/09 12:08 AM
07/25/09 12:08 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
We rebuilt a '69 GTX 440 to stock specs,except used a 484 Mopar cam.Stock Carter AVS carb,iron intake and exhaust manifolds,906 heads unported-stock valves,only a .030 overbore.2-1/2 exhaust through Dynomax turbo mufflers.Auto 727 with a custom converter,mild stall.Initially it ran the stock 3.23 gear,then 4.10 gear.The GTX ran a 13.9 with the 4.10 gear,in drive shifts at 6200 RPM,never ran it with the 3.23.Tires are BFG 295/50/15's on 10" Weld wheels.The car has A/C and a choppy idle,but ok with the air on.It runs good with the 4.10's,but I always wanted to try it with a 3.55,the 3.23 gave it awesome top end and highway passing power though.I have tuned many stock or near stock 440's and think a 3.55 gear is perfect for an all around driver.The cam as installed may be your low end problem,you could try to advance the cam timing by 4*.BTW the 484 cam in the GTX will shred the tires!(I may have the gears backwards for the dragstip time,it may have been with the 3.23's)I'll check,it is a friends car,and the times were in the early '90's. RT
[Re: RTSrunner]
#384949
07/25/09 01:00 AM
07/25/09 01:00 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
It's the cam, or you need more compression.. which do you want to fix? The 440 can handle the .484 but needs real 10:1 not Morpar magic wanna be factory maybe 9:1 that you have... I'd swap the cam
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: forphorty]
#384951
07/25/09 02:25 AM
07/25/09 02:25 AM
Posts: 577 Grand Rapids, MI
11secondC
Grand Rapids, MI
1967 VIP 4400 lbs w/driver = 14.17@97, 2.08 60', worn out stock bottem end '62 413, 484 cam, 452's, 750 Carter + RPM, 1.75" headers, 2400 stall, 3.55's, 26" BFG's and it would boil those anywhere in first gear...
[Re: RTSrunner]
#384953
07/25/09 08:58 AM
07/25/09 08:58 AM
Mr.Yuck
Brookeville, Md
I ran the sumit 488 cam in a 67 coronet w/ a basic cast piston (maybe 9:1) 440. stock 906 heads, headers, RPM intake 750DP, 175K convert (2800) car ran consistant 12.90 @ 104. It had the 484 in it when I got it and 3.55's. what a dog. it could barley run 14.0's IMO for a 440 powered B-body that's too slow.
