Post deleted by Defbob
[Re: Cab_Burge]
#384827
07/24/09 09:22 AM
07/24/09 09:22 AM
Re: No pinion snubber and hard launches....
[Re: Blakcharger440]
#384828
07/24/09 09:29 AM
07/24/09 09:29 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I am wondering if I will have any leaf spring wrap up problems with my Dana 60 that does not have a pinion snubber. My car is a 70 Charger RT with factory springs. I probably will be making around 600 at the crank when all is done with the engine.
I am wondering if I will have any problems with launching on street tires or the drag radials that I plan to put on for track days.
I do have a set of Cal Tracs that I could put on and would that help any?
A friend who had a similar engine and a Dana 60 without pinion snubber in a 70 Charger and a built automatic and SS springs running mid elevens didnt seem to have a problem with it...will i have any more problems due to mine being a 4speed?
I tried a hard launch with my Challenger/416/Dana/HD springs and the diff yoke hit my floorpan. I had the correct pinion angle but the springs just wrapped up way too much. I got CalTracs.
[Re: topside]
#384831
07/24/09 12:37 PM
07/24/09 12:37 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
I have a 9.80's car with dana and leafs with no snubber, never hit the floorpan, have wrapup, or anything else...i wouldnt trade what i have for 10 cal track setups
[Re: bonefish]
#384832
07/24/09 12:39 PM
07/24/09 12:39 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
if your pinion snubber works ,you got problems.put the caltracs on it.however i have seen mixed results using caltracs and STOCK springs.
What springs would be good to run with the Caltracs that would be good for the track and would work fine on the street?
I dont like the rear end up in the air like you get with the SS springs and would they be too firm for the street?
#384833
07/24/09 12:47 PM
07/24/09 12:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Talk to Caltrac's about their springs
[Re: bonefish]
#384834
07/24/09 12:55 PM
07/24/09 12:55 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Mine work great...
[Re: BB70DUSTER]
#384835
07/24/09 01:34 PM
07/24/09 01:34 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Mine work great...
i tried it with my car and it didnt work to good BUT my car weighs 4,129 lbs.i went to the monos and it works great.all you can do is try it.
[Re: bonefish]
#384837
07/24/09 01:56 PM
07/24/09 01:56 PM
Pinion snubbers are for your grandpa's 5th ave ...when he over-loads the trunk ...and goes over a bump .... ......THEN the driveshaft and rear end does not contact the floor pan ! HEY ... that was the original INTENT of that part designed by Ma Mopar !!
[Re: bonefish]
#384838
07/24/09 01:56 PM
07/24/09 01:56 PM
Posts: 30,466 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
[Re: dOc !]
#384842
07/25/09 12:28 AM
07/25/09 12:28 AM
Posts: 3,665 NE OHIO
kevin69bman
NE OHIO
And do you know the exact reason WHY Ma Mopar did this ... on those Hemi and I believe some 6 Pack cars ?
Becuse they worked and made the cars hook
I still run one with my super stock springs
