Got the 408 Out For The Fist Time Today #384410
07/23/09 04:30 PM
07/23/09 04:30 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I must say I'm impressed. It's been a long time coming, but well worth the wait. The 340 it replaced ran a best of 7.24 @ 95.04 (1/8) on pump gas with a hydraulic cam. I don't know what this one will run but it's much stronger. The 275/60 M/T ET Street Radials are no match for it, even high gear. I have the 3" mandrel bends for the exhaust and a 950HP ordered for it so I probably wont run it much until everything gets here.
Thanks John Cope for the valve body, Dram for the rotating assembly and RyanJ for the head work .
Re: Got the 408 Out For The Fist Time Today [Re: justinp61] #384411
07/24/09 02:27 AM
07/24/09 02:27 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
you will have lots of fun with the 408 , whats the specs.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Got the 408 Out For The Fist Time Today [Re: Ian] #384412
07/24/09 09:23 AM
07/24/09 09:23 AM
W. Kentucky
W. Kentucky
72 360 block, line honed, square decked, studded main caps, Diamond pistons .005 in the hole, 10.85-1, K-1 steel 4" crank with 2.100 rod journals, Comp Star 6.125" H beam rods. The rotaings assembly is balanced.
The Edelbrock heads were ported by Curits Boggs and freshened by RyanJ with new Ferrea 2.055/1.60 valves, 930 Comp springs, heads milled to 55cc chambers, five angle valve job, they flowed in the low 290/220s after Curtis worked on them.
Hughes 1.6 roller rockers, Hughes push rods, Hughes 260/264 @ .050, .626/.633 flat solid camshaft, in at 102.5*. Cloys true roller chain. Edelbrock Victor 340 intake that's port matched and has had the plenum cleaned up, HVH 1" super sucker, currently has a Quick Fuel Q-750 on it but I have a 950 on the way.
Re: Got the 408 Out For The Fist Time Today [Re: justinp61] #384413
07/25/09 03:49 AM
07/25/09 03:49 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
this must be you ,that combo will make good power.
