What coil springs are you running?
#384378
07/23/09 04:00 PM
07/23/09 04:00 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
What coil springs are you running? Car weight? Ladder or 4 link? What's the best bang for the buck single adjustable shock? Most seem to run 110#-130#, I remember Lonnie saying he had 210# springs awhile back. I need to order better shocks and springs soon, I've been playing with 130# and 170# springs but the tires are shot so I haven't learned anything yet, just getting more confused.
Re: What coil springs are you running?
[Re: MegaDart]
#384380
07/23/09 06:06 PM
07/23/09 06:06 PM
STRANGE HYPERCOIL 170# spring
[Re: ProSport]
#384382
07/23/09 06:38 PM
07/23/09 06:38 PM
Posts: 716 Indiana
65dragnet
Indiana
QA1 130lb. 4-link 3413 lbs with driver
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
[Re: 65dragnet]
#384383
07/23/09 06:48 PM
07/23/09 06:48 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
QA1 single adjust shocks and QA1 130lb springs. Ladder bar, 3380 race weight.
[Re: ProSport]
#384384
07/23/09 07:41 PM
07/23/09 07:41 PM
Posts: 535 Ohio
racerAL
Ohio
QA1 130# springs moroso adjustable drag shocks ladder bar 3550# -if the side walls are shot on those slicks i wouldn't do anything with the springs or shocks til you can get some new meats..imo....i chased my tale for a month trying to figure out why my car wouldn't 60' consistently..it was the slicks(sidewalls)..i tried everything from diff. air pressure to going up and down with the ladder bars..-it was the slicks- put a new set on and it was right back to normal..every car will react different to changes, but you need to have a constant and that constant needs to be good slicks..get those then make changes as needed..
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: racerAL]
#384385
07/23/09 08:54 PM
07/23/09 08:54 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Q A1 single adj shocks and IIRC their 120# springs. 4 link rear and 2820 car weight.
Now I'm really starting to think I want the springs MEGADART has though. Can't qiut place why
[Re: WILD BILL]
#384386
07/23/09 09:15 PM
07/23/09 09:15 PM
Dyno1
I work in tech and sales at QA1. QA1 offers single and double adjustable coil over shocks for many applications. There are single, double and the "R" single adjustable shocks that bolt in the stock location. QA1 has spring lengths in 7", 9", 10", 12" and 14" and spring rates from 85lbs to 650lbs. You can also look at www.qa1.net for more information. Give me a call at 800-721-7761 if you need any help. thanks, Dan
[Re: racerAL]
#384389
07/23/09 10:31 PM
07/23/09 10:31 PM
ProSport
Akron, Ohio
Yea the tires will make a big difference but on my last car I could turn the knob on the shocks and feel the difference by pushing down on the back of the car. With the Chassis Engineering shocks on this car, which I just recently paid to have rebuilt, I can turn them from full soft to full hard and there's no difference.
My friend that works on Chassis stuff said that a ladder bar car should be very stiff when pushing down on the rear of the car, is this true?
[Re: Cab_Burge]
#384391
07/24/09 06:09 PM
07/24/09 06:09 PM
ProSport
Akron, Ohio
My coil-overs total length is 16 3/8, fully compressed is 12". Does that sound right? Seems like only 4 3/8" of travel. I'm looking at the Strange #S5206 single adjustable shock, would that be a good one for my car? Here's a link.............
[Re: S/ST 3040]
#384392
07/24/09 06:35 PM
07/24/09 06:35 PM
Posts: 4,647 aotearoa
rebel
aotearoa
Art Morrison 32" ladder-bars, Strange dbl-adjustable shocks w/Hyperco 110# springs.
2710-2740 lbs. race weight.
looking at your pic it looks like you have more than an inch of squeeze on your springs. on a post on here earlier i think it was chassisman suggested that the springs only be compressed 1". how well are your rear suspension working with your springs compressed that much as you have? surely your extention must be somewhat limited?
#384393
07/24/09 06:36 PM
07/24/09 06:36 PM
Quicktree
170#s, what the heck you holding up a house?
#384396
07/24/09 10:50 PM
07/24/09 10:50 PM
Posts: 877 ky
68roadrunner
ky
dont let them make fun i have 170# also, 3450#51% on rear. but this may be to stiff
[Re: ProSport]
#384397
07/24/09 11:03 PM
07/24/09 11:03 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I went with 140 lb springs to start, 117" wheelbase, 2900 pound car and a LOT of engine setback.... how do I pick too? I assume I'll have to launch it and see what needs attention, maybe swap them out down the road, but it's gonna be my starting point....
CrAzYMoPaRGuY
[Re: rebel]
#384399
07/24/09 11:57 PM
07/24/09 11:57 PM
ProSport
Akron, Ohio
Pics can be deceiving, my 12" springs are compressed one inch with shocks fully extended and they look the same way on the car.
[Re: Quicktree]
#384400
07/25/09 08:07 AM
07/25/09 08:07 AM
a heavy early b body. i guess a 1.28 60 foot footbraking isnt working too good with a #170 lb spring.
#384401
07/25/09 08:21 AM
07/25/09 08:21 AM
Quicktree
heck no you need more, then you would get into the 1 teens
[Re: WILD BILL]
#384402
07/25/09 08:54 AM
07/25/09 08:54 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
Bill, 90% of the cars here will work fine with qa1 stuff. I tested 4 sets of qa1, 1 set of afco and finally the Eibach. Eibach was the best spring by FAR, and were only a few dollars more...
I have Jerry Bickel on my new car and when I can find out what weight they are will replace with Eibach...
[Re: MegaDart]
#384403
07/26/09 03:32 AM
07/26/09 03:32 AM
Posts: 27,478 So Cal
autoxcuda
So Cal
What was better about them? Did you put them on a spring rater them out of the box to check how close they were to advertised. Some brands are more off than others. Some lose there rate faster especially if they are "lightweight" versions with reduced amount of coils.
