72 charger 446-6 #384285
07/23/09 02:29 PM
07/23/09 02:29 PM
Canada
shadowauto Offline OP
Canada
Hi I am having a problem with my 440-6 with only 14000 miles on a full rebuilt it ran perfect for 4 years and this years it dies on me when I come to a stop I change the alternator to make sure I have enough juice at idle no diference also change regulator same problem then i change the 6AL box (was a mopar unit)now it the real MSD and I have the same problem when I put it in nutral a 200 feet before I stop it ok could it be my tork converter my RPM is set at 1100 before use to be at 775-800 any sujestion thanks Francis.the motor is a roller the lift is 529 the six pack was new mopar 5 years ago the head are 452
Re: 72 charger 446-6 [Re: shadowauto] #384286
07/23/09 02:48 PM
07/23/09 02:48 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
More than likely a carb issue. Do you know the outboard fuel mix check trick?
btw-- Is that a v code car?
Re: 72 charger 446-6 [Re: RemCharger] #384287
07/23/09 03:54 PM
07/23/09 03:54 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
yaaaa.... you've checked everything but the thing causing the problem..... carb issue .
Re: 72 charger 446-6 [Re: shadowauto] #384288
07/23/09 04:19 PM
07/23/09 04:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
floats getting stuck??? Do you drive it much?
Coming soon!!!!
Re: 72 charger 446-6 [Re: shadowauto] #384289
07/23/09 04:22 PM
07/23/09 04:22 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Nice rides!
Common sense is a flower that does not grow in everybody's garden
Re: 72 charger 446-6 [Re: RemCharger] #384290
07/23/09 04:52 PM
07/23/09 04:52 PM
Canada
Canada
Its not a v code car its a 340 its the orange one in the pictures thanks .
Re: 72 charger 446-6 [Re: Mr.Yuck] #384291
07/23/09 04:55 PM
07/23/09 04:55 PM
Canada
Canada
I don't drive it much I am on my second tank this year so you figure it car problem thanks Francis.
Re: 72 charger 446-6 [Re: Mr.Yuck] #384292
07/23/09 06:46 PM
07/23/09 06:46 PM
Canada
Canada
Any quick cure or the carb has to come a parts thanks Francis
Re: 72 charger 446-6 [Re: shadowauto] #384293
07/23/09 06:58 PM
07/23/09 06:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If your MSD unit has a laser, clean the lense. I had the same problem once, I fought it for months & finally fixed it with a Q-tip.
Re: 72 charger 446-6 [Re: Alaskan_TA] #384294
07/23/09 10:49 PM
07/23/09 10:49 PM
Detroit, MI
Detroit, MI
Just tune the damn thing, it doesn't need to come apart...
