Driveshaft Alignment on Dana 60
#384254
07/23/09 01:30 PM
07/23/09 01:30 PM
Posts: 89 oregon
ramcharger1964
oregon
I changed out an 8.75 on my 64 Polara for a Dana rear. As I installed my driveshaft this week I noticed that the pinion yolk on the Dana is centered, whereas the 8.75 yolk is offset about 1-2 inches. More investigation showed that the tranny/motor is also offset to match the rear. So in essence my driveshaft has about a 1-2 degree left to right angle. Is this going to be a problem for a 10.5 second car???? Gears are 4.10 and should see about 6800 rpm.
Hell B!tch Racing Co.
Re: Driveshaft Alignment on Dana 60
[Re: ramcharger1964]
#384255
07/23/09 06:14 PM
07/23/09 06:14 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I have just been through this, the Dana i bought came from a tube chassis car with rack and pinion. I cut different length tubes on both sides, swapped them side for side along with the half shafts and got the offset back. I pulled it apart and measured everything first though. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Post deleted by Defbob
[Re: hemi69cuda]
#384258
07/23/09 07:40 PM
07/23/09 07:40 PM
#384259
07/23/09 07:54 PM
07/23/09 07:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
As long as the trans and pinion are parallel its not a issue... it just works the U-joints ALL the time but if you have big power you would like the complete drive line to be in line under power
[Re: hemi69cuda]
#384260
07/23/09 07:55 PM
07/23/09 07:55 PM
Posts: 89 oregon
ramcharger1964
oregon
Dana is same width as the stock 8.75 although I moved the springs inboard and got offset wheels. The setup is brand spankin new, never been run.... I didn't even notice until I put my max wedge exhaust in and noticed that the pass side pipe was way closer to the driveshaft than the driver side. Man I really don't want to pull this thing again. I'll give the shop I purchased it from (leonards Offroad) a call and see what he thinks.
#384262
07/23/09 08:00 PM
07/23/09 08:00 PM
Posts: 89 oregon
ramcharger1964
oregon
The engine should be somewhere in the neighborhood of 680hp. It is a 500 RB built by Damon Kuhn. Trans is a CRT pro II trans brake, stall is 4800 - 5200. I am trying to set the car up as w wedge type clone and to run somewhere in the high to mid 10 sec range.
