Post deleted by Defbob #384107
07/23/09 11:55 AM
07/23/09 11:55 AM
Anonymous OP
Anonymous OP
Re: GregZ is he still here ? #384108
07/23/09 12:07 PM
07/23/09 12:07 PM
Marion, SC USA
69RR383 Offline
69RR383  Offline
Marion, SC USA
Contact Greg through the "Contact Us" option on his website Magnumhp.com -- thats how I got some parts I needed about 2 months ago. I believe he was in the process of helping his wife with another business then.
Re: GregZ is he still here ? #384109
07/23/09 12:09 PM
07/23/09 12:09 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
he does'nt post much but i think he is still around...i was looking at his low mount alt stuff last year..but have'nt looked at is site since then.
Re: GregZ is he still here ? #384110
07/23/09 07:03 PM
07/23/09 07:03 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
noticed he hasn't made a post in some time I wanted to order a part from him
Hey Fred, I bought my parts through Dram. Dan said he was a good friend of Gregs. And he sourced the parts for me.
Post deleted by Defbob [Re: 572B1] #384111
07/23/09 07:29 PM
07/23/09 07:29 PM
Anonymous OP
Anonymous OP
Re: GregZ is he still here ? #384112
09/06/09 10:39 AM
09/06/09 10:39 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
It's about a question regarding a low mount DMI bracket that also doubles as a mount for a crank trigger. I wanted to know what parts he posted about.
anyone have pics of this bracket with an MSD 160 amp alternator?
or an ATI damper with a Jesel belt drive?
I need to know which pick up to get standard 3/4" or mini 3/8"
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: GregZ is he still here ? [Re: RylisPro] #384113
09/06/09 11:32 AM
09/06/09 11:32 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
thanks
I have an ATI balancer with a jesel belt drive
Re: GregZ is he still here ? [Re: RylisPro] #384114
09/06/09 11:43 AM
09/06/09 11:43 AM
AndyF Offline
AndyF  Offline
I make a TDC pointer with crank trigger mount for the Jesel setup and I have an optional 3/8 pickup mount. I don't think that Doty ever tooled up his 3/8 pickup mount.
If you're looking for the DMI bracket you can buy them from Mancini Racing or direct from Doty. I think GregZ went out of business and moved on to a different gig but I haven't talked to him for a long time now.
Re: GregZ is he still here ? [Re: AndyF] #384115
09/06/09 11:46 AM
09/06/09 11:46 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Andy, Mike made the prototype with the 3/8" pickup for me. I thought they were going to make it to production.
Re: GregZ is he still here ? [Re: Bigcube] #384116
09/06/09 12:17 PM
09/06/09 12:17 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey Bigcube
how far back is that mini bracket adjustable? my ATI damper has the magnets built in
not like yours with the MSD wheel in front
I'm guessing it should work
just need to know if everything will clear
on mancini's site it says the 3/8" x 24 x 1.25 OAL pick up brackets are available on special order
http://chucker54.stores.yahoo.net/lowmobialbrc.html
Screw it!!! I'll just buy everything and postup my own pics
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: GregZ is he still here ? [Re: RylisPro] #384117
09/06/09 12:25 PM
09/06/09 12:25 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
It should adjust far enough back. What is interesting is there appears to be different size wheels? Andy, yours looks larger than the balancer by quite a bit. And RylisPro, your built in wheel looks larger than the damper part? My wheel is almost exactly the same diameter as the balancer.
Re: GregZ is he still here ? [Re: Bigcube] #384118
09/06/09 12:50 PM
09/06/09 12:50 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Yes it is larger by roughly 1/4", good call!
I guess I will have to mount the pickup flush to the bracket
with the hex nut on the back to make space
do you think I will still have room?
thanks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: GregZ is he still here ? [Re: RylisPro] #384119
09/06/09 01:04 PM
09/06/09 01:04 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Not sure you could mount it flush with the one I have.
This was an early prototype. Seems like it could adjust flush with the jam nut on the back if the ledge in the slot was reversed.
Re: GregZ is he still here ? [Re: Bigcube] #384120
09/06/09 01:19 PM
09/06/09 01:19 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
could you mount the above "L" bracket backwards so it looks like a backwards "7"?
that might work?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: GregZ is he still here ? [Re: RylisPro] #384121
09/06/09 01:30 PM
09/06/09 01:30 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
No, the slot it fits in has a slight curve to follow the radius of the balancer. It won't fit on backward.
Here's an old pic with the big pickup and a mini alternator.
Re: GregZ is he still here ? [Re: Bigcube] #384122
09/06/09 01:44 PM
09/06/09 01:44 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Looks like I'll have to get the dremel tool and cut out a groove to get it to fit
I'll make it work!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: GregZ is he still here ? [Re: Bigcube] #384123
09/06/09 02:40 PM
09/06/09 02:40 PM
AndyF Offline
AndyF  Offline
The damper in the picture I posted above has the BB Chevy bolt pattern so that is an 8 inch Chevy trigger wheel. I also make the pickups for the smaller Mopar wheel.
Post deleted by Defbob [Re: AndyF] #384124
09/06/09 02:47 PM
09/06/09 02:47 PM
Anonymous OP
Anonymous OP
Re: GregZ is he still here ? #384125
09/06/09 03:32 PM
09/06/09 03:32 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
is anyone concerned about the MSD picking up some type interference or cross signals from the alternator being so close to it ???
that's why I asked about the 3/4" and 3/8" pickup
MSD 8275 is a shielded 3/8" pickup
http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Products/Distributors/8275_instructions.pdf
it is grounded and I was also going to cover it with BX cable armor & that should take care of the interference
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: GregZ low mount alternator discussion here now #384126
09/16/09 05:48 PM
09/16/09 05:48 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I got my DMI bracket today! I talked to Mike Doty about my dilemma and he helped me out. Here is how I wil configure it
the lower bolt on the bottom doesn't quite fit cuz the bolt is too thick & I have to enlarge the groove
(the 2 bolts that mount the bracket itself are too long & are just for mock up. I need to get shorter allen head bolts)
my setup is using the MSD 160 amp alternator and you have to buy MSD bracket 5158 for it
here is the custom bracket Mr. Doty helped me with. it is a 3/4" pickup
I have a custom ATI damper with built in magnets that enlarge the wheel 1/4". it should clear with pleanty of clearance.
(the bolts should not be there, they are too long, I need to get shorter ones)
pic of my pulley alignment for good measure
I'll need a couple of washer to get everything perfect
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
