I got my DMI bracket today! I talked to Mike Doty about my dilemma and he helped me out. Here is how I wil configure it
the lower bolt on the bottom doesn't quite fit cuz the bolt is too thick & I have to enlarge the groove
(the 2 bolts that mount the bracket itself are too long & are just for mock up. I need to get shorter allen head bolts)
my setup is using the MSD 160 amp alternator and you have to buy MSD bracket 5158 for it
here is the custom bracket Mr. Doty helped me with. it is a 3/4" pickup
I have a custom ATI damper with built in magnets that enlarge the wheel 1/4". it should clear with pleanty of clearance.
(the bolts should not be there, they are too long, I need to get shorter ones)
pic of my pulley alignment for good measure
I'll need a couple of washer to get everything perfect
