small block head gasket,which one? #383655
07/22/09 09:11 PM
07/22/09 09:11 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
I want to get my compression up,what is the thinnest head gasket available that will do the job in a 318,about 9.5 comp.street driven.
What are the best parts for doing a set of 318 302 casting swirl port heads on a budget?
Re: small block head gasket,which one? [Re: moparborn] #383656
07/22/09 09:15 PM
07/22/09 09:15 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
P4120094 if you can find them. .026-.028 compressed.
Re: small block head gasket,which one? [Re: MoparforLife] #383657
07/22/09 09:18 PM
07/22/09 09:18 PM
Re: small block head gasket,which one? [Re: MoparforLife] #383658
07/23/09 12:57 AM
07/23/09 12:57 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
mr gasket 1121 is the same gasket...
Tony
70 AARCuda Vitamin C
Re: small block head gasket,which one? [Re: 70AARcuda] #383659
07/23/09 03:05 PM
07/23/09 03:05 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
On mancini racings website it says the mopar performance p4120094 is .024-.028 with a 4.060 bore. Which compressed thickness would this gasket actually be since it states two different thicknesses? Also which is the better gasket the Mr. gasket or the mopar performance?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: small block head gasket,which one? [Re: 73cuda340] #383660
07/28/09 11:37 AM
07/28/09 11:37 AM
Caldwell. Id
E
edbux Offline
edbux  Offline
E
Caldwell. Id
Check the bore diameter of the Mr. Gasket. The bigger the whole in the gasket, the less compression you will have.
1967 Dart 270 360/727
Re: small block head gasket,which one? [Re: edbux] #383661
07/28/09 12:08 PM
07/28/09 12:08 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Mr gaskets are 4.14" Bore....the newest MP thin gaskets are also 4.14" bore, they don't make the 4.06" bore ones anymore.
I used the Mr gaskets, haven't had a chance to fire it up yet.
2017 Grand Cherokee Overland
Re: small block head gasket,which one? [Re: 73cuda340] #383662
07/29/09 12:14 AM
07/29/09 12:14 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
they are the same gasket..
they both came available within days of each other...order both trying to get one set...
got both sets...
Tony
Re: small block head gasket,which one? [Re: 70AARcuda] #383663
07/29/09 12:45 AM
07/29/09 12:45 AM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
I don't think I would go through the trouble of changing a head gasket for a compression increase unless there was another reason to change the gasket anyways.
The result will be so insignificant it won't even be noticeable. It may raise your compression from 9.5 to 9.6 if you're lucky.
