Page 1 of 3 1 2 3
Post your best .400 light and car weight with driver #383535
07/22/09 08:41 PM
07/22/09 08:41 PM
Columbus, Ohio
wheelsup68dart Offline OP
Columbus, Ohio
Also post whether or not you had to deep stage, and what your car will run flat out.
My dart will go a best of 9.53 2 seasons ago with low gear trans, I could cut .001 light with no delay and shallow stage
This season on shallow stage and running a best of 9.60's with standard low gear I cannot go better than .030 on shallow stage, however if I modify my stage routine to roll in deep I can go .00? and even red. My car weighs in at 2615 with me in it.
The cuda I ran at Martin is capable of running 8.90 and Weighs in heavier than my Dart, I was able to cut consistent .002-.009 with no delay in box and shallow stage, however I ran delay that made my lights between .012 and .026 in eliminations, IMO the box could have cost me more races than it helped me with.
Re: Post your best .400 light and car weight with driver [Re: wheelsup68dart] #383536
07/22/09 08:48 PM
07/22/09 08:48 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
Can cut consistent .015 to .025 lights on .400 pro tree with 3300# true ten five Cuda. Running 5.50s and 60s on 1/8. Leaving with transbrake and full stall on converter which is about 4,500. Leave the line on motor only and bring nitrous in at .02 seconds.
Re: Post your best .400 light and car weight with driver [Re: wheelsup68dart] #383537
07/22/09 08:49 PM
07/22/09 08:49 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
.4 protree...3700 lbs car...footbrake no electronics. Car ran 11.60's....
best is .007...deep staged...and I got lucky. I was not consistant at all.... It was my first time running protree too..lol.
Re: Post your best .400 light and car weight with driver [Re: silverfish] #383538
07/22/09 08:50 PM
07/22/09 08:50 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
Oh yeah and no deep staging. That is shallow staging.
Re: Post your best .400 light and car weight with driver [Re: silverfish] #383539
07/22/09 08:57 PM
07/22/09 08:57 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Lonnie correct me if I am wrong, Norwalk 2 years ago in the finals, wasn't mine a .027 against your .021? I cannot remember, mine average between .050 and .070 with out any delay, staged normal and weigh in at 3150#
Re: Post your best .400 light and car weight with driver [Re: dartman366] #383540
07/22/09 09:20 PM
07/22/09 09:20 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
3350 no box
best ever 028
normally 40 to 70
this is shallow staging(i always stage the same way, just habit)
chip at 3400..were i to turn the launch chip up to 4500 or so, i have no doubt i could tighten those numbers up a little, but i would have to rake my seat out after every launch
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Post your best .400 light and car weight with driver [Re: dartman366] #383541
07/22/09 10:00 PM
07/22/09 10:00 PM
Columbus, Ohio
Columbus, Ohio
Actually it was your .021 to my .027 you just could not quite run the number.
Re: Post your best .400 light and car weight with driver [Re: wheelsup68dart] #383542
07/22/09 10:28 PM
07/22/09 10:28 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
How much roll-out should I use in my practice tree for a 26.5" tire with 1.42 60 fts?
Re: Post your best .400 light and car weight with driver [Re: wheelsup68dart] #383543
07/23/09 11:46 AM
07/23/09 11:46 AM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
My best on the .400 Pro tree is .004 and another .007 (pulled them both out of my azz). Car weighs 3160, 1.29 60', flat out - don't know yet - still working on it - but a best of 9.35 so far - there's more in it.
I have gone -.002 red on the .400 Pro (intentiaonally taking a shot at it), but I'm typically .020 - .030. I shallow stage - no box.
Re: Post your best .400 light and car weight with driver [Re: Lil Demon] #383544
07/23/09 11:57 AM
07/23/09 11:57 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
#2850 Dart in S/gas trim, box zeroed out 6000rpm launch netted low teen lites on divisional tree, not sure if that was .370 or .400 though?
8.2x's @ 165 1.18 60'
I'm pretty close to Eric for full tree, 1.13-1.14
new car needs 1.16-1.17 to stay green
Re: Post your best .400 light and car weight with driver [Re: wheelsup68dart] #383545
07/23/09 12:19 PM
07/23/09 12:19 PM
N.E. Ohio
OhioGTX Offline
OhioGTX  Offline
N.E. Ohio
Not sure where you are going with this thread but got an idea that you think Heavy Cars and .400 tres make for a good mix...I am not sure..I can average an .04 to .030 with a shallow stage and have seen a few not a lot but a few .00 lights when I deep stage.
Making the car hit a consistant .00 would require some changes....some easy some not so easy...If I was running an IHRA or NHRA class on a .400 tree I would probably change cars but for the 10.0 stuff we do I will just keep trying to get better at deep staging...
68 GTX, 9.38 at 144, Best Machine 540..
Re: Post your best .400 light and car weight with driver [Re: OhioGTX] #383546
07/23/09 12:20 PM
07/23/09 12:20 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
2850 with driver
nothing special of a brake, just standard turbo action.
on .400 pro tree I have time in the delay box.
car runs 9.95 flat out, 1.35 sixty foot times.
Small tire car, alky injected gets out of the beams very quickly.
Dad has it now down in Texas. I want to get down there from seom 10.00 events. Absolutly deadly car for something like that.
Re: Post your best .400 light and car weight with driver [Re: Garceau] #383547
07/23/09 12:23 PM
07/23/09 12:23 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
3235 with driver
.083 avg
shallow stage
WAXER
Re: Post your best .400 light and car weight with driver [Re: wheelsup68dart] #383548
07/23/09 12:30 PM
07/23/09 12:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
At the last t&t I ran a .000 on my first pass COMPLETELY by luck and had people convinced I actually knew what I was doing then followed that with a string of crappy lights to prove I didn`t. 3150lbs. w/me.
Re: Post your best .400 light and car weight with driver [Re: wheelsup68dart] #383549
07/23/09 12:59 PM
07/23/09 12:59 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
3300 with driver
10.60 index
car will run all out 10.17
footbrake
launch 2200
.046 best light bumping in to stage NOT DEEP
typically lights are in the .060-086 range.
1.46 60'
Re: Post your best .400 light and car weight with driver [Re: Dart Racer] #383550
07/23/09 01:07 PM
07/23/09 01:07 PM
.400 shallow (one time) with 135x15 front tires, 3150 lbs foot braking. I saw the prestage and stage lights dim when the starter hit the button and left on that
Re: Post your best .400 light and car weight with driver [Re: Cab_Burge] #383551
07/23/09 01:18 PM
07/23/09 01:18 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Probably a stupid question..but..
Once both cars are staged the tree is activated super quick..at what point does it get activated. I get in shallow because i dont want the car to still be moving forward towards getting in deep with my brake button not pushed in, obviously.(0therwise the car wont move)
Do they wait until both cars have "found their spot"?? to activate the tree?
what i am trying to say is that say i want to get deeper than just turning on the bottom bulb, and the other guy is already in the gate, do they wait for my car to stop creeping deeper and then setting the brake and going to the wood before activating the tree
1.41 best 60 foot
6.56 at 104.17
Re: Post your best .400 light and car weight with driver [Re: B3422W5] #383552
07/23/09 01:22 PM
07/23/09 01:22 PM
MI
RickRoss Offline
RickRoss  Offline
MI
Best light was a .033 with 1.38 60 ft,Car is 3170 with me in it.I just need to drive at the finish line.
Re: Post your best .400 light and car weight with driver [Re: B3422W5] #383553
07/23/09 01:47 PM
07/23/09 01:47 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
go into the stage beam first and bump a little deeper before the other guy stages as alot of people want to stage last...
Tony
70 AARCuda Vitamin C
Re: Post your best .400 light and car weight with driver [Re: B3422W5] #383554
07/23/09 01:50 PM
07/23/09 01:50 PM
Lil Demon Offline
Lil Demon  Offline
Nope - once all four bulbs are lit etiher Autostart (if on) will activate the tree or the starter will do it manually. If you are deep staging - make sure to write it on your windows and get there in a hurry.
If I am next to you and see that on your window - if we are in Quals or TNT - I will wait for you before I pull all the way in. If we are in elims, I won't wait very long - and you may run across someone who will double-bulb you just to screw with you.
The class I normally run does not allow deep staging.
Page 1 of 3 1 2 3
