Help...What is wrong?
#383342
07/22/09 06:24 PM
07/22/09 06:24 PM
Posts: 196 West Central Indiana
Mr.Runum
Need some help/thoughts 2002 QC LB 2500 ram 4x4 5.9gas headers, K&N, MSD (Igint, Coil, Plug Wires)Superchip. 103,000 miles. Well maintained does not smoke or make any noise, Unpluged PVC Hose and the pass side hose blocked off held hand over oil filler port the engine built up pressure not vac. Intake gasket should be good, never has used oil,plugs are clean. Truck wt. #6500 4:10 gears Michelin LT265 on a recent trip 325mi got 13.85 mpg. Heres the prob, keeps giving a p0301 code (#1 cyl misfire) New cap and rotor, new plug, changed out #1 plug wire, new injector, stll same code. Using an Infered thermometer #1 cyl runs about 160 degs cooler than #2 and idels rough. What are your thoughts? Mr.Runum
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
Re: Help...What is wrong?
[Re: Mr.Runum]
#383343
07/22/09 06:38 PM
07/22/09 06:38 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
What did that #1 cyl spark plug look like?
Sounds electrical or sensor related.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
[Re: MoparJ]
#383344
07/22/09 06:43 PM
07/22/09 06:43 PM
Mr.Runum
#1 looked good and I even had a new one. I put the plug on the engine and started, had a good blue spark. Yet the header tube #1 is still 192deg vs #2@360deg at idel.
[Re: Mr.Runum]
#383345
07/22/09 07:08 PM
07/22/09 07:08 PM
MoparJ
Simi Valley, CA
Do a compression test, just to ward off possibility of internal issues.
I wouldn't be surprised if it wasn't the cam or crank position sensor, or another like sensor. Do you notice any missing, or can you hear it through the exhaust? Have you tried clearing the code?
[Re: MoparJ]
#383346
07/22/09 07:38 PM
07/22/09 07:38 PM
Mr.Runum
I have cleared the code with my superchip. it does miss and you can hear it feel it at idle. A compression test is about the only thing I have not done yet. Maybe a bent valve, bad cam?
Mr.Runum
[Re: Mr.Runum]
#383347
07/22/09 09:11 PM
07/22/09 09:11 PM
Mr.Runum
Ran a compression test on #1,2,3 cyl 2 &3 were at 175psi cyl #1 was 150psi.
Mr.Runum
[Re: Posest]
#383350
07/23/09 11:46 AM
07/23/09 11:46 AM
MoparJ
Simi Valley, CA
Possibly, but since a code for a sensor isnt popping up, I would still be inclined to check into a slight intake gasket leak.
The 5.2/5.9 engines do have some tendancy to kill these over time, which causes detontation, oil consumption issues and some slight misfiring.
