Page 4 of 4 1 2 3 4
Re: Acetone and its many uses [Re: cudadon] #383142
07/24/09 11:21 AM
07/24/09 11:21 AM
L.I. N.Y. Hemi Street
HemiGreg Offline OP
HemiGreg  Offline OP
I uSE"
AMISH JUICE
5 OZ TO A GALLON MIX AND GET STUCK IN A DITCH IN PA.
THEN ACCOSTED BY A BUNCH OF PEOPLE WEARING BLACK & WHITE
sometimes im attacked by a stampede of black and white cows, then I use "Cow Juice" additive. the extra calcium makes my Rods stiffer
but seriously I use various mixes depending on the atmospheric pressure and air density/tempature at the time.
generally a mixture of:
Acetone
Xylene
Kerosene
Tranny fluid.
Acetone and Xylene are approx the same cept Xylene is carcinogen so which ever one is gotten free.
Kerosene has high BTU content and boosts octane and provides additional power (Kjoles) per cyl filling.
ATF also provides additional BTU power and octane boost plus some lubricity propites to top cylinder area.
for 10 gallons of 89 pump gas run 4:2:2. ratio
4 ozAcetone
2 oz Kerosene
2 oz ATF
Re: Acetone and its many uses [Re: HemiGreg] #383143
07/24/09 11:32 AM
07/24/09 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
In the first few post this was something to read but
since then MOST of this is just BS
Re: Acetone and its many uses [Re: MR_P_BODY] #383144
07/24/09 02:27 PM
07/24/09 02:27 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
After 25 years rebuilding marine diesels, soaking rusted nuts with anything is a waste of time, Man discovered heat long before acetone, If there is any rust we don't reuse the fastener anyway, Now back to the Amish ladies or sheep ect...
Post deleted by Defbob [Re: MR_P_BODY] #383145
07/24/09 02:36 PM
07/24/09 02:36 PM
Re: Acetone and its many uses #383146
07/24/09 03:12 PM
07/24/09 03:12 PM
HemiGreg Offline OP
HemiGreg  Offline OP
Fred,
"as long as they will drink from the cup, I will fill it with knowlege from my fountain."
famous quote: HemiGreg July 24,2009
they can spill it out and waste good info at their own demise!!!!!
yet another great quote. im on a roll pin.
Re: Acetone and its many uses [Re: HemiGreg] #383147
07/24/09 05:37 PM
07/24/09 05:37 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Acetone
Xylene
Kerosene
Tranny fluid.
4 ozAcetone
2 oz Kerosene
2 oz ATF
What is the makeup of Marvel Mystery Oil?
I know that some add it at every fill up and use it in place of lead additives to keep the exhaust valve seats happy.
Post deleted by Defbob [Re: topbrent] #383148
07/24/09 06:01 PM
07/24/09 06:01 PM
Re: Acetone and its many uses #383149
07/24/09 07:26 PM
07/24/09 07:26 PM
HemiGreg Offline OP
HemiGreg  Offline OP
SECTION XII - Ingredients/Identity Information
Ingredient # 01
Ingredient Name BENZENE, 1,2-DICHLORO-
CAS Number 95501
Percent 0
Ingredient # 02
Ingredient Name MINERAL SPIRITS
CAS Number 8052413
Percent 0
Ingredient # 03
Ingredient Name NAPTHENIC HYDROCARBONS
CAS Number 64742525
Percent 0
Page 4 of 4 1 2 3 4
