Re: 904 race trans wish list [Re: dc426] #383064
07/23/09 08:53 PM
07/23/09 08:53 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The diameter of the Borg Warner 35 convertor neck is around 3/16"ish bigger than the 904. Basic the company making the convertor machines up a stepped neck, the diameter that drives the pump is the standard size, the diamter that runs on the pump bush is the larger size. Most importantly, this adds thickness to the bottom of the drive slot where 904 necks are prone to cracking.
Basically every reputable convertor shop in Australia has this as an option (Big Neck). Autoflite Engineering (Dominator Convertors) were the first to do this many years ago. I have a pic somewhere, but I would have to dig it up.
AL....
Alan Jones
Re: 904 race trans wish list [Re: LA360] #383065
07/23/09 09:28 PM
07/23/09 09:28 PM
Tampa Florida
dc426 Offline OP
gotta keep'm separated
dc426  Offline OP
Tampa Florida
hmm, interesting. I haven't heard of this in the states....anyone?
DC
Re: 904 race trans wish list [Re: dc426] #383066
07/23/09 10:44 PM
07/23/09 10:44 PM
LA360 Offline
LA360  Offline
How Plentiful are Borg Warner 35 Automatic transmissions over there? They are everywhere over here.
AL.....
Alan Jones
Re: 904 race trans wish list [Re: dc426] #383067
07/23/09 11:19 PM
07/23/09 11:19 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
DC
Chris many shops here in the states offer this on 904 converters.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 904 race trans wish list [Re: topfueldart] #383068
07/23/09 11:50 PM
07/23/09 11:50 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
SS/AH Hemi Cars wouldnt run 904 internals if it werent worth it.
Oh, it's worth it.......but, they don't use that lightweight stuff because it strong
and I doubt there is one thing in them that originally came in a 904.
I understand your point. I just dont agree with the viewpoints of many Mopurists that its 727 or nothing. 904's have their worth as well. I already have a good number of performance 904 parts, so for me, I'll stick with the 904 until im proven its not worth it anymore. Which will be much farther than most would ever dare.
You have about another .75 sec before you start mowing thru anything stock in a 904. One of my friends went thru this with his, on a 11.2 car the stock 904 would go for 2 years with just the standard performance rebuild, manual VB and small snout converter.
When he swapped to a better motor that runs 10.5's it started getting 3-4 runs before the clutches were gone, when the clutch issue was fixed it started breaking cases and input shafts every few passes. He has a built 904 in it now but the price is almost the same as an entry level lenco.
Re: 904 race trans wish list [Re: dc426] #383069
07/24/09 12:30 AM
07/24/09 12:30 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
DC
go to turboaction.com
click on instruction on left side of page...
then click on tech tip #6...,,,and it reads,,,and it has pictures...
It is not unusual for a Torqueflite 904 converter to crack the pump drive neck as shown above. Turbo Action to help stop this problem, was the first company to use chrome moly pump necks. This helped, but you can help this problem even more with our help. Machine the ring on your reaction shaft off and then request to make your converter pump neck solid on the inside (N0 Step). If you machine this ring off and you do not make pump neck thicker, you will not hurt your transmission or converter. If you install a solid neck converter on a stock transmission, you will have problems.
Tony
70 AARCuda Vitamin C
Re: 904 race trans wish list [Re: 70AARcuda] #383070
07/24/09 04:04 AM
07/24/09 04:04 AM
LA360 Offline
LA360  Offline
The ones we use are a little different, see below
AL....
Alan Jones
Re: 904 race trans wish list [Re: LA360] #383071
07/24/09 08:37 AM
07/24/09 08:37 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
What really would be neat would be, to modify the 904
to accept the 727 converters.
