Re: 904 race trans wish list
[Re: scottb]
#383047
07/22/09 01:13 PM
07/22/09 01:13 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
5 clutches in the front clutch pac
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: dc426]
#383050
07/22/09 07:56 PM
07/22/09 07:56 PM
Posts: 296 CT
turbocolt2.4L
CT
rollerized gov support a must ,wide pump gears if you machine little off top end plate you can fit 5 frictions in forward too and all the above.I dont think you need harded input shaft i have a stocker in mine over 500 hp to wheels 2500 lbs car leave 6000rpm on brake 27 psi of boost.mid 9's.
[Re: dc426]
#383052
07/22/09 08:15 PM
07/22/09 08:15 PM
dartman366
Mt. Vernon, Ohio
anyone else wanna add anything?
same oiling mod's and build procedure's as a 727, high quality clutch's, band's, bushing's and thrust bearing's, and keep clearance's tight.
[Re: dartman366]
#383053
07/22/09 08:53 PM
07/22/09 08:53 PM
Posts: 6,139 Melbourne , Australia
LA360
Try and find a core with steel planetries if you can. Sell your 727 and convertor to pay for the parts of your 904. Parts I'd buy- Roller rear support.
re-use your brake or pick up a Griner or similar.
Quality rebuild kit including new bushes and thrusts etc.
If your budget allows an aluminium drum and a hardened Input shaft would be nice.
We usually run a bIgger neck (BW35) as well. AL.....
Alan Jones
[Re: LA360]
#383054
07/22/09 08:59 PM
07/22/09 08:59 PM
Posts: 5,000 Tampa Florida
dc426
gotta keep'm separated
Tampa Florida
not sure what your talking about here?
[Re: Chris2581]
#383057
07/22/09 10:57 PM
07/22/09 10:57 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
I wouldn't swap
I wouldn't either.That 727 is going to last a lot longer than the 904 will,even if the 904 is race prepped with all the goodies.
It all depends on what its going behind, your intended use, and how well the trans is built... SS/AH Hemi Cars wouldnt run 904 internals if it werent worth it.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#383059
07/22/09 11:10 PM
07/22/09 11:10 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Oh, it's worth it.......but, they don't use that lightweight stuff because it strong and I doubt there is one thing in them that originally came in a 904.
[Re: S/ST 3040]
#383060
07/23/09 01:19 AM
07/23/09 01:19 AM
topfueldart
Renton Wa
I understand your point. I just dont agree with the viewpoints of many Mopurists that its 727 or nothing. 904's have their worth as well. I already have a good number of performance 904 parts, so for me, I'll stick with the 904 until im proven its not worth it anymore. Which will be much farther than most would ever dare.
[Re: LA360]
#383062
07/23/09 02:19 AM
07/23/09 02:19 AM
Posts: 384 Australia
Mcode69
Australia
thrusts etc.
Find a '76 or later 904 for a core, they come with the steel planetaries. The pre '76 ones have aluminium planetaries and are a weak link.
[Re: Mcode69]
#383063
07/23/09 09:24 AM
07/23/09 09:24 AM
dc426
Tampa Florida
larger diameter neck on convertor
how is this accomplished? what about the pump, what do you do there? DC
