Single master cyl. replace #382951
07/22/09 08:55 AM
07/22/09 08:55 AM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
Getting rid of the single master cylinder on a 66 Coronet, is there a dual that will bolt in its place? Does the rod need to be changed? Looking for a cheap ,easy way to do it...but who aint! By the way it is a race car.
Re: Single master cyl. replace [Re: Thor500] #382952
07/22/09 09:53 AM
07/22/09 09:53 AM
AndyF Offline
AndyF  Offline
Go with the late model aluminum master cylinder and get the 4-2 adapter plate. Eberg is usually selling them on ebay or in the parts page on here.
Re: Single master cyl. replace [Re: AndyF] #382953
07/22/09 10:55 AM
07/22/09 10:55 AM
Replacement truck master cylinders that look like the aluminum ones and even include the car type resevoir can be used. They're all of $26.00 at Autozone right now. Use one of the 4-2 billet adapters and you're good to go!
As small as they are the weight diff. between the cast iron and aluminum is minimal.
Re: Single master cyl. replace [Re: Thor500] #382954
07/22/09 11:45 AM
07/22/09 11:45 AM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
Good info. thanks. Any idea what year/model truck i should ask for? Can I use the old rod?
Re: Single master cyl. replace [Re: Thor500] #382955
07/22/09 02:03 PM
07/22/09 02:03 PM
I asked for '86 Dodge IIRC.
Re: Single master cyl. replace [Re: Thor500] #382956
07/22/09 02:39 PM
07/22/09 02:39 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
I need to do this on the 66 Charger.
Does any body have a link to Eberg's post or whatnot on the 4 to 2 adapter?
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Single master cyl. replace [Re: MoparJ] #382957
07/22/09 04:15 PM
07/22/09 04:15 PM
