Classic Motorsports in Mn. E-85 carb specialists
#382942
07/22/09 08:02 AM
07/22/09 08:02 AM
Posts: 654 ohio
dbran451
ohio
do any of you know anything about them they do e-85 conversions using your existing metering blocks and the price is about half what it is to replace them with billet ones.
Re: Classic Motorsports in Mn. E-85 carb specialists
[Re: dbran451]
#382947
07/23/09 03:13 PM
07/23/09 03:13 PM
Posts: 16,928 NC
440Jim
NC
Ask for details on what will be machined, and what parts will be replaced. You can machine the gas metering blocks to something usable, but ask if they enlarge the main well, modify idle fuel restriction, power valve channel restriction enlargement, etc. For optimization, you really should have the boosters changed, and the holes in the metering blocks feeding the boosters enlarged. IMO, the QF metering blocks are a good price because they are resized vs stock and are anodized to fight corrosion. If you machine the existing ones, you have bare aluminum exposed. The QF blocks also have screw in emulsion bleed holes (many to select) for tuning.
Does your carb already have screw in air bleeds? Because the air bleeds will need to be changed. Larger needle and seats too.
[Re: 440Jim]
#382948
07/24/09 12:31 PM
07/24/09 12:31 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Jim is correct Mark Sullens converted my 950HP. Runs like a top, I only needed 1 jet change and 1 air bleed change to get it spot on!! Great customer service. I bet he called me a dozen or more times in the 2 weeks after I got the carb back from him. If I were looking to go to E85 Id either use Mark or Heath Daniels. Both guys seem to be spot on with their advice and have great customer service.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
