Torsion Bar Installation #382892
07/22/09 04:23 AM
07/22/09 04:23 AM
Anonymous OP
Anonymous OP
Hi i am over hauling the front end of my 65 dart and i was wondering what is the proper way in installing the torsion bar so that it does not over tighten when i raise the car. I have it out b/c i replaced the LCA bushing and strut rod bushing with poly. I just wanted to make sure that i when i tighten everything that the t-bar is in the right setting
Chris
Re: Torsion Bar Installation #382893
07/22/09 07:59 AM
07/22/09 07:59 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I believe the only tightening on the torsion bar is related to ride height. Get the ride height the way you want it, be sure the front is level, and that's it.
Re: Torsion Bar Installation [Re: 1fastrunner] #382894
07/22/09 10:15 AM
07/22/09 10:15 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
They just slide in and are held in by a clip in back - the tightening adjusts the ride height.
Ride eternal, shiny and chrome
Re: Torsion Bar Installation [Re: DirectSubjection] #382895
07/22/09 11:23 AM
07/22/09 11:23 AM
Ohio
V
viperakron Offline
viperakron  Offline
V
Ohio
Be sure to grease both ends well. A dry bar can break.
Re: Torsion Bar Installation [Re: viperakron] #382896
07/22/09 12:17 PM
07/22/09 12:17 PM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
FWIW - last time I did this I was told to have the LCA in full drop position when you insert the T-bar.
Re: Torsion Bar Installation [Re: Gusteve] #382897
07/22/09 10:39 PM
07/22/09 10:39 PM
Here
Here
If you don't, you could run the risk of sliding the bar one face off on the hex end.
