Re: Got a call from my machine shop today K1 crank is junk [Re: gregsdart] #382560
07/22/09 12:12 PM
07/22/09 12:12 PM
First off, you are making good power to run that fast at 3300 lbs. That said, I hope you either have an aftermarket block, or are working with a low deck B motor based around the 400 block. To me, it is all about keeping the rotating weight down to the minimum, and keep a good eye on clearances during assembly. I started off just like you did, not much mentorship. But guys on the board here helped tremendously.
If you don't have mikes and gauges to measure every last part you are going to put together, get them. They are a lot cheaper in the long run than situations like this.
I have a full set of outside mikes, a GOOD dial bore gauge, dial indicators, etc and use them all. Even the best shops can have something slip by.
That said, Reher Morrison is someone I do business with when ever I can. They are great to deal with, and I trust their work and reputation. So that leads me to believe the cause of all this is not with their work. Also, I own their engine assembly books. I suggest you read all their tech articles on line as well.
You have suffered the pain and expense of a motor gone sour, now it is time to reap the rewards of a very well done build! A new plan for a shortblock is in order, so ask what the guys are running.
My personal favorite is like 440jims 512 lowdeck combo, a 512 cube 4.25 stroke 4.375 bore lowdeck motor with a very light bobweight. An aluminum rod motor set up this way with aluminum caps, and a girdle will handle about anything you can throw at it and live due to a bobweight of about 2000 grams. A RB motor like mine comes in at 2432 and is steel rod, and flexes the megablock I have bad enough to cause me grief. It lives, makes great power, but I would be better off with a lowdeck 4.5 bore deal!
Last, but not least, is oil control and flow. Did you ever have even a small dip in oil pressure during braking? all oil passages the proper size, at least 10 psi per 1,000 rpm? minimum 15w40 or preffered 20w50 race oil? A good pan with a side bucket? All this is important, and I paid money in the form of hurt parts to learn it.
The rod bearings looked good as well. They were a little messed up from the junk from the main bearings. I suspected that the three center main caps were the culprit once I pulled it down. I assume the outer bolts never were torqued to begin with on the original build. This block is not being reused. I have a tall deck R3 at the machine shop right now. It was a 4.00 crank and it saw 7000rpm two times.
Re: Got a call from my machine shop today K1 crank is junk #382561
07/22/09 12:45 PM
07/22/09 12:45 PM
Mansfield, Tx
Jacob Pitt Offline OP
Mansfield, Tx
gregsdart this is not my big block I'm having problems with. The 499 in my Challenger that I built 2 years ago is still running great. I did use a Mega block and a good assembly in it. This motor I'm building now is for the Dart Sport I purchased a year and a half ago that came with a stroker small block that I wanted more e.t. out of to go race Super Street and some Quick Door races. I started with all new stuff except the block. Now it will be all new. It did manage to run a 6.42@106 before the problems occured. Next build will be a tall deck R3 and custom dome Diamond pistons.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Got a call from my machine shop today K1 crank is j [Re: Jacob Pitt] #382562
07/22/09 01:42 PM
07/22/09 01:42 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
The way I see your bearings looks like everything was ok at the time you build it, clearance included. the damage on the main bearing and crank is because of two reasons: Crank was completely out of the balance or you have inadecuate front dumper.
Re: Got a call from my machine shop today K1 crank is junk [Re: Jacob Pitt] #382563
07/22/09 03:20 PM
07/22/09 03:20 PM
gregsdart Offline
gregsdart  Offline
gregsdart this is not my big block I'm having problems with. The 499 in my Challenger that I built 2 years ago is still running great. I did use a Mega block and a good assembly in it. This motor I'm building now is for the Dart Sport I purchased a year and a half ago that came with a stroker small block that I wanted more e.t. out of to go race Super Street and some Quick Door races. I started with all new stuff except the block. Now it will be all new. It did manage to run a [Email]6.42@106[/Email] before the problems occured. Next build will be a tall deck R3 and custom dome Diamond pistons.
Sorry bout that, missed the part about smallblock. Hope you get it all sorted out!
Re: Got a call from my machine shop today K1 crank is j [Re: CompWedgeEngines] #382564
07/22/09 03:48 PM
07/22/09 03:48 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
"My own opinion is its better to use a good ProGram 2 bolt cap and studs than a 4 bolt conversion on the stock block stuff."
This is also my opinion and exactly what I did with my 416.
Re: Got a call from my machine shop today K1 crank is j [Re: BobR] #382565
07/22/09 04:24 PM
07/22/09 04:24 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have read this same thing many times, Im using good caps, and a hughes main girdle on my stroker build...
Re: Got a call from my machine shop today K1 crank is junk [Re: 10sec440] #382566
07/22/09 05:53 PM
07/22/09 05:53 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
The block had the center three caps were splayed and I had replaced the outer allen head holts with grade 8 bolts because I couldn't torque the allen heads.
This is a red flag for me, don't really know what it means.The main cap bolts or studs should be torqued the same while being line bored as they are while being run. Other than that it looks like assembly error to go that bad that fast. Insufficient bearing clearance?
I would expect this to be the problem. And since it is the 3 center caps that are splayed. That is why they look like they do. JMO
Re: Got a call from my machine shop today K1 crank is j [Re: Moparnut426] #382567
07/22/09 07:04 PM
07/22/09 07:04 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
, third season on pro gram 2 bolt caps w/studs turning in the 7ks stock 59* block stroker, its the major thrust thickness that spooks me
Re: Got a call from my machine shop today K1 crank is j [Re: emarine01] #382568
07/22/09 09:25 PM
07/22/09 09:25 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
THE crank is craked in 20 places.you guys say the main caps? the only way to do that is UNWANTED HARMONIC
Re: Got a call from my machine shop today K1 crank is j [Re: cbarracuda] #382569
07/22/09 09:35 PM
07/22/09 09:35 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We tore down a 440 marine engine with a similar failure due to detonation from old fuel and clogged cyl head cooling passages, cracked the crank in a dozen places and tried to knock out the center main cap, the damage looked just like the posted pics
Re: Got a call from my machine shop today K1 crank is junk [Re: Jacob Pitt] #382570
07/24/09 07:11 PM
07/24/09 07:11 PM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
We would lean toward detonation or very high cylinder pressure,you can detonate a engine with 10.0 cr on race gas,there are several causes to look at ,dyno testing with wideband o2 is a must.if the problem was oil supply related ,the end mains and the rod bearings would show lack of lube,if the problem was damper related ,it would show on the end mains,also install wideband o2 in car.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Got a call from my machine shop today K1 crank is junk [Re: Jacob Pitt] #382571
07/24/09 11:00 PM
07/24/09 11:00 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
If the bolts were replaced after the line hone...that was the problem.
Engine by DeTar http://www.kansasbadman.com
