M/T 29.5x10.5 vs. 29.5x10.5W #382391
07/21/09 07:48 PM
07/21/09 07:48 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Does the W tire(#3062W) have a stiff sidewall? And the 3062 does not, correct?
I know new tires and new shocks eventually will help me but I'm thinking the W tire may last longer with the stiffer sidewall and hook better of course with the 11.2" tread.
As I've said before, I don't race much and don't have time or money to go to the track and hone the tires off all day. Plus I've had a few members here tell me the 3062 only hooks good for 25-35 runs.
I run it down the street every now and then too and I know that's not good for them.
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: ProSport] #382392
07/21/09 08:24 PM
07/21/09 08:24 PM
i have run the W's for years and i just now bought a set of 29.5 x10.5 x 15 M/T's
they are not stiff sidewalls, i needed a little narrow tire for my 63 plymouth, i gave up on hoosiers as they go away after 38 passes on my car, sidewall just collapses. even at 12 -13 lbs they look like they are flat.
ill let you know how they do this sunday at ol time drags at etown. the 29.5 x 10.5 M/T just were delivered yesterday.
im curious as well. hopefully they work better than the 30 x10.5 x 15 hoosiers.
i almost went with the goodyears but M/T are giving a $50.00 check card with each purchase of a pair of M/T slicks. hope this helps.
Re: M/T 29.5x10.5 vs. 29.5x10.5W #382393
07/21/09 08:34 PM
07/21/09 08:34 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.mickeythompsontires.com/strip.php?item=ETDrag
look at the difference between the W and the regular 10.5 x 29.5...
the W is a bigger tire.
Tony
70 AARCuda Vitamin C
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: 70AARcuda] #382394
07/21/09 08:39 PM
07/21/09 08:39 PM
the sidewall on the w is huge. it didnt fit under my 63 plymouth with the new strange s60, my chassis guy is going to cut my axle tubes to get them to fit under trhe wells and minitub the car.
heres a picture of the w's under my 65 dodge. they are huge!
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: 70AARcuda] #382395
07/21/09 08:40 PM
07/21/09 08:40 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Bob, the 29.5x10.5w is almost the same as the 29.5x11.5. I think the only diff is the circumference is 93 on the w tire and 94 on the other. I ran the 11.5 tire when my car wasn't back-halfed and it worked pretty good. Had 438 runs on the tires.
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: ProSport] #382396
07/21/09 08:47 PM
07/21/09 08:47 PM
NC
barracuda man Offline
NC
I don't think the W tire has the stiff sidewall.I run the w tire and can't wear them out.Been on the car for a season now.It's a heavey tire 30 pounds but it hooks.Might try the 29.5x10.5x15 next time.
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: barracuda man] #382397
07/21/09 08:50 PM
07/21/09 08:50 PM
the w tire is definitely a stiff sidewall, all the outlaw guys run them,
there is also a stiff sidewall M/T slick thats not a W and has a stiff sidewall/.
they put as S vnext to the part#.
Re: M/T 29.5x10.5 vs. 29.5x10.5W #382398
07/21/09 10:33 PM
07/21/09 10:33 PM
The W's are 1" more tread surface and about 2" wider sidewall.
Re: M/T 29.5x10.5 vs. 29.5x10.5W #382399
07/21/09 10:41 PM
07/21/09 10:41 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Only the 33/10.5s are huge not the 29.5's. I run the true 10.5 stiff sidewall on a 12" rim with 11lbs of air and only seem to get 25-30 passes also. (1.25 60') I wish they made a 31" true 10.5!
The 2 tires appear to be dam near the same size
3062S 29.5/10.5-15S 27 M5 9555 10 13.2 10.2 29.9 94
3062W 29.5/10.5-15W 30 M5 9555 10 13.6 11.2 29.6 93
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: bigtimeauto] #382400
07/21/09 10:48 PM
07/21/09 10:48 PM
I change them out every 35 passes. They go away after that...I am going to try a set of Goodyear 10.5 x 30.0 next set..Anyone else tried the Goodyears on a high horsepower 10.5 tired car???
poppaj
Re: M/T 29.5x10.5 vs. 29.5x10.5W #382401
07/22/09 12:09 AM
07/22/09 12:09 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I'm definitely not buying new tires every 25-35 passes, no way. I'll put 14x32's on it before I'll do that.
I'd like to try drag radials as I've heard they last awhile but I'm afraid my car won't hook consistently.
Does the W tire with the stiff sidewall seem to last longer than the regular 29.5X10.5?
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: ProSport] #382402
07/22/09 07:53 AM
07/22/09 07:53 AM
an8sec70cuda Offline
Bob, if you can fit the W under the car then use them. The W tires DO have a stiffer sidewall than the true 10.5. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: ProSport] #382403
07/22/09 09:07 AM
07/22/09 09:07 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
No. The W will not last longer. The W is a bigger tire and has a stiff sidewall. The regular 29.5x10.5x15 tire lasts longer on my car.
My issue is my car is heavy and hits the tire HARD. The W works well for this. It will go away in 40 passes or so in my experience. If your car doesnt hit the tire very hard and is lighter, you will get away with them longer. Thats my
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: 66coronet] #382404
07/22/09 09:42 AM
07/22/09 09:42 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Bob first off why wouldnt you use a radial tire if you use it for a street car ? I have had all of the 29 X 10.5 Hoosiers on my car. I would guess that our cars are about the same weight CI but I have Cal Tracs and you have a ladder bar car.The C-11 @ 13 psi will put my car on its bumper if I jack the rear shocks up and loosen the front shocks.
Re: M/T 29.5x10.5 vs. 29.5x10.5W #382405
07/22/09 03:41 PM
07/22/09 03:41 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
poppaj
I have Goodyear # 1790 slicks on a 8.90 Dart, it's a 10.5 X 30, using a 12 inch wheel. Best slick I have ever used. The 1790 is a stiff sidewall, soft D4B compound.
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: an8sec70cuda] #382406
07/22/09 10:02 PM
07/22/09 10:02 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
The W tire may fit right on my car with these wheels, if not I could sell the wheels and get a little different offset.
Dave those Goodyears look like the hot ticket, I wonder how long they'll last with that soft compound though.
It amazes me that guys put hundreds of passes on a set of 14x32's but only get 25-35 passes on 10.5's.
I think the 315 ET street radial would fit my car perfectly but traction with this tire seems to be hit or miss depending on the car. I need something that's gonna hook all the time since I don't get to the track very often. My trap RPM is already 7000 so with an ET street radial that doesn't grow the trap RPM 'could' be even higher.
The Hoosier 29.5x10.5 has some nice dimensions, part#18192DO6. It has some extra heighth(30.6) to knock my trap RPM down a hair, and also has an 11.1" tread.
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: ProSport] #382407
07/23/09 12:22 AM
07/23/09 12:22 AM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
What about the 29.5x11.5 phoenix . Best brand I've ever put on my car and I have tried them all.
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: Hunted Duck] #382408
07/23/09 01:02 AM
07/23/09 01:02 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
are'nt alot of guys going very fast on drag radials?
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: Hunted Duck] #382409
07/23/09 06:21 PM
07/23/09 06:21 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Jeff, the 29.5X10.5 Phoenix looks like the right dimensions for me. Phoenix 14x32 was the best tire I ever had on my DartSport and I bought them used!
Re: M/T 29.5x10.5 vs. 29.5x10.5W [Re: Joshs68] #382410
07/23/09 06:25 PM
07/23/09 06:25 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Yes, low 7's. But they are very dialed in cars with expensive double adjustable shocks etc. I'd love to try the ET Street radials but it's expensive to 'try' tires. 50% of the people I talk to don't hook on street radials. But they do work if the car is sorted out.
Will the ET street radials last a full season when hitting the track 5 or 6 times and occasional short trips to local car shows, and ice cream?
