M/T 29.5x10.5 vs. 29.5x10.5W
#382391
07/21/09 07:48 PM
07/21/09 07:48 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Does the W tire(#3062W) have a stiff sidewall? And the 3062 does not, correct? I know new tires and new shocks eventually will help me but I'm thinking the W tire may last longer with the stiffer sidewall and hook better of course with the 11.2" tread. As I've said before, I don't race much and don't have time or money to go to the track and hone the tires off all day. Plus I've had a few members here tell me the 3062 only hooks good for 25-35 runs. I run it down the street every now and then too and I know that's not good for them.
Re: M/T 29.5x10.5 vs. 29.5x10.5W
#382393
07/21/09 08:34 PM
07/21/09 08:34 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://www.mickeythompsontires.com/strip.php?item=ETDraglook at the difference between the W and the regular 10.5 x 29.5... the W is a bigger tire.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#382394
07/21/09 08:39 PM
07/21/09 08:39 PM
the sidewall on the w is huge. it didnt fit under my 63 plymouth with the new strange s60, my chassis guy is going to cut my axle tubes to get them to fit under trhe wells and minitub the car. heres a picture of the w's under my 65 dodge. they are huge!
[Re: barracuda man]
#382397
07/21/09 08:50 PM
07/21/09 08:50 PM
I don't think the W tire has the stiff sidewall.I run the w tire and can't wear them out.Been on the car for a season now.It's a heavey tire 30 pounds but it hooks.Might try the 29.5x10.5x15 next time.
the w tire is definitely a stiff sidewall, all the outlaw guys run them, there is also a stiff sidewall M/T slick thats not a W and has a stiff sidewall/. they put as S vnext to the part#.
#382398
07/21/09 10:33 PM
07/21/09 10:33 PM
The W's are 1" more tread surface and about 2" wider sidewall.
#382399
07/21/09 10:41 PM
07/21/09 10:41 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Only the 33/10.5s are huge not the 29.5's. I run the true 10.5 stiff sidewall on a 12" rim with 11lbs of air and only seem to get 25-30 passes also. (1.25 60') I wish they made a 31" true 10.5!
The 2 tires appear to be dam near the same size
3062S 29.5/10.5-15S 27 M5 9555 10 13.2 10.2 29.9 94
3062W 29.5/10.5-15W 30 M5 9555 10 13.6 11.2 29.6 93
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#382400
07/21/09 10:48 PM
07/21/09 10:48 PM
I change them out every 35 passes. They go away after that...I am going to try a set of Goodyear 10.5 x 30.0 next set..Anyone else tried the Goodyears on a high horsepower 10.5 tired car??? poppaj
#382401
07/22/09 12:09 AM
07/22/09 12:09 AM
ProSport
Akron, Ohio
I'm definitely not buying new tires every 25-35 passes, no way. I'll put 14x32's on it before I'll do that. I'd like to try drag radials as I've heard they last awhile but I'm afraid my car won't hook consistently. Does the W tire with the stiff sidewall seem to last longer than the regular 29.5X10.5?
[Re: ProSport]
#382402
07/22/09 07:53 AM
07/22/09 07:53 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Bob, if you can fit the W under the car then use them. The W tires DO have a stiffer sidewall than the true 10.5. CHIP
[Re: ProSport]
#382403
07/22/09 09:07 AM
07/22/09 09:07 AM
Posts: 826 Georgia
66coronet
Georgia
No. The W will not last longer. The W is a bigger tire and has a stiff sidewall. The regular 29.5x10.5x15 tire lasts longer on my car.
My issue is my car is heavy and hits the tire HARD. The W works well for this. It will go away in 40 passes or so in my experience. If your car doesnt hit the tire very hard and is lighter, you will get away with them longer. Thats my
#382405
07/22/09 03:41 PM
07/22/09 03:41 PM
Posts: 1,283 Colorado,U.S.A
4404dart
Colorado,U.S.A
I have Goodyear # 1790 slicks on a 8.90 Dart, it's a 10.5 X 30, using a 12 inch wheel. Best slick I have ever used. The 1790 is a stiff sidewall, soft D4B compound.
[Re: an8sec70cuda]
#382406
07/22/09 10:02 PM
07/22/09 10:02 PM
ProSport
Akron, Ohio
The W tire may fit right on my car with these wheels, if not I could sell the wheels and get a little different offset. Dave those Goodyears look like the hot ticket, I wonder how long they'll last with that soft compound though. It amazes me that guys put hundreds of passes on a set of 14x32's but only get 25-35 passes on 10.5's. I think the 315 ET street radial would fit my car perfectly but traction with this tire seems to be hit or miss depending on the car. I need something that's gonna hook all the time since I don't get to the track very often. My trap RPM is already 7000 so with an ET street radial that doesn't grow the trap RPM 'could' be even higher. The Hoosier 29.5x10.5 has some nice dimensions, part#18192DO6. It has some extra heighth(30.6) to knock my trap RPM down a hair, and also has an 11.1" tread.
[Re: Hunted Duck]
#382409
07/23/09 06:21 PM
07/23/09 06:21 PM
ProSport
Akron, Ohio
What about the 29.5x11.5 phoenix . Best brand I've ever put on my car and I have tried them all.
Jeff, the 29.5X10.5 Phoenix looks like the right dimensions for me. Phoenix 14x32 was the best tire I ever had on my DartSport and I bought them used!
