shackles for E body with super stock springs #382294
07/21/09 05:35 PM
07/21/09 05:35 PM
ohio
ta340 Offline OP
ta340  Offline OP
ohio
looking for shackles that look stock that have
both 9/16 bolt for E body bushing and 1/2 bolt
for the bushings on the super stock springs.
Re: shackles for E body with super stock springs [Re: ta340] #382295
07/21/09 05:40 PM
07/21/09 05:40 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Like this?
http://chucker54.stores.yahoo.net/rearshackles.html
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: shackles for E body with super stock springs [Re: HealthServices] #382296
07/22/09 05:45 PM
07/22/09 05:45 PM
ohio
ta340 Offline OP
ta340  Offline OP
ohio
Like this?
those have the same size bolt at each end.
I need 9/16" bolt at one for the 1" bushing in the
E body and 1/2" bolt at the other end for the 7/8"
bushing in the super stock springs.
Re: shackles for E body with super stock springs [Re: ta340] #382297
07/22/09 07:46 PM
07/22/09 07:46 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The shackles in the link are the pieces you should be using.... ..They've always worked for me....
