go all the way with this: an 8 blader & on your drill press(while supporting the front shaft) press them forward until you have ~.040" clearance between the vanes & the pump body(reduces parasitic recirculation), then weld on an anticavitation plate to the vanes, then take off the timing cover & mill the front so the vanes are ~.040" from the flat, taking into consideration your particular gasket thickness and in the 2 water passages on each side there are sand casting parting lines which are slightly restrictive, deburr them,use washers to reduce your bolt length(if the thread engagement was perfect before) and space the pulley forward to maintain your previous alignment.
