Best E Body Door Panel Repair Glue #381297
07/20/09 05:57 PM
07/20/09 05:57 PM
Tampa, FL
70RTvert Offline OP
70RTvert  Offline OP
Tampa, FL
Does anybody know what is the best glue for repairing broken or split E body oem interior panels?
I've had some luck with contact cement but just wondering if anybody has found something better.
Doug
Re: Best E Body Door Panel Repair Glue [Re: 70RTvert] #381298
07/21/09 12:57 PM
07/21/09 12:57 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
This subject has been touched on a number of times here.
There isn't a glue that works real well.
The plastic compound that the panels are made from doesn't accept glue well, and the panels are stressed a bit when attached to the doors so that they end up recracking.
Re: Best E Body Door Panel Repair Glue [Re: RP's R/T's] #381299
07/21/09 01:10 PM
07/21/09 01:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
https://board.moparts.org/ubbthreads/show...e=4#Post4916353
Member "etek" fixed some door panels on a Challenger he is working on. THe above link is to his restoration page on this site.
Maybe send him a PM as to what he used.
Re: Best E Body Door Panel Repair Glue [Re: burdar] #381300
07/23/09 09:38 AM
07/23/09 09:38 AM
Tampa, FL
70RTvert Offline OP
70RTvert  Offline OP
Tampa, FL
Thanks for your help.
Re: Best E Body Door Panel Repair Glue [Re: 70RTvert] #381301
07/23/09 10:32 PM
07/23/09 10:32 PM
ohio
jaycuda Offline
jaycuda  Offline
ohio
East wood garage sell's what is called plastex .This will fix any plastic and never break you can get in colors but standard is black . How it works is you drop the one part clear liquid into a plastic dust and it melts instantly and is spredable or hit it with a 2nd drop and its flow's more then within one minute its hard and 10 minuts its rock hard. good luck.
Re: Best E Body Door Panel Repair Glue [Re: jaycuda] #381302
06/24/11 02:48 AM
06/24/11 02:48 AM
Los Angeles, CA
71_dramaqueen Offline
Los Angeles, CA
"Won't adhere to polypropylene or polyethylene" -Eastwood website
hmmmmm, let's see what are E body door panels made of again......
Re: Best E Body Door Panel Repair Glue [Re: 71_dramaqueen] #381303
07/08/11 01:20 AM
07/08/11 01:20 AM
MN
astrobuf Offline
astrobuf  Offline
MN
This is about the only stuff in the world that will reliably bond polyethelyne and polypropylene.
http://www.stealth316.com/2-dp8005.htm
Most serious body shop suppliers carry the stuff. It's expensive, but it works.
Astrobuf
So, are you really a Rocket Scientist?
Re: Best E Body Door Panel Repair Glue [Re: astrobuf] #381304
07/08/11 02:24 AM
07/08/11 02:24 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use Fusor for plastic repairs, bonding metal to plastic, etc... I'm sure they would carry something that would work. However like 3m and others, they have their own special gun you need to buy and it's not cheap.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
