What cam for this engine? 440 With eddy heads
#380853
07/20/09 11:49 AM
07/20/09 11:49 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I am going to change my cam and would like some opinions please. I want to stay hydraulic and the car is street/strip so its gotta idle.
Currently: 66 .030 440 with Crane 230 duration .480 lift. TRW 2355 six pack forged pistons, edelbrock 84cc 2.14 1.81 heads, street dominator with QT pro 850, headers. FBO ignition, 727 with TA 3300-3500 converter with 3.91 gears 27" tire.
My car runs 12.3, I want it to run 11.5 and I think I could benefit with a better cam. I know its hard to tell without PV numbers, but I am looking for idea about what name or brand. An idea whats to radical, like a .750 lift and too lame.
Thanks.
Thanks.
RS23L7 4-Speed
Re: What cam for this engine? 440 With eddy heads
[Re: Mopar_Mike]
#380856
07/20/09 05:08 PM
07/20/09 05:08 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You are asking a lot for a cam change, roughly 100 hp. Ain't gonna happen without some serious changes. Can you reduce car weight? Consider a hydraulic roller cam? Head work? If you really want to stay hydraulic and gain that much power, you will need to extend the rev range(roller) or stroke it to get the airflow at lower revs to make that much power. There are sure to be guys on hear that will chime in with combos they have built that may meet your goals.
[Re: Mopar_Mike]
#380857
07/20/09 06:20 PM
07/20/09 06:20 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
ok, you have a 67 Dodge,maybe 37-3800lbs? you can do it. i have a 68 satellite,approx 3700lbs with driver,runs 11.41@118.5.440 +0.055,10.78 comp,m1 single plane,825 mighty demon,prepped stealth heads i have a purple 509 cam,idles in gear at 750/800 rpm.the downside to this is i have to run a vacuum pump for the brakes,there is a revised version of this cam-wider lobe seperation will pull better vacuum.Comp etc all do similar cams,i also like their XE/XEHL cams check piston valve clearance. exhaust must be right.i have 1 7/8 hooker comps into 3",aero chambers and finish at diff. i also have lighter,SRP, pistons with a performance balance. get your suspension right,i have qa1's front ,rancho rear shocks.clamped rear mopar xhd springs no caltracs no snubber,small block tbars. i shift at 5900 and trap at 6/6100.this is with a 28" et street radial,3.91 gears and 3200 stall converter. yes it should run quicker with more converter/gear Good luck Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 383man]
#380859
07/20/09 07:43 PM
07/20/09 07:43 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Were the heads gone thru before you bolted them on?
[Re: Mopar_Mike]
#380860
07/20/09 08:00 PM
07/20/09 08:00 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
What kind of car do you have? I have a question for you. How do you like your turbo action converter? i am getting ready to order one fore my 440 73 dodge dart.I have a engine combo pretty close to what you have except I have stock size valve, home ported 906 heads and 1.6 roller rockers. I am running 4.10 gears and 275/60/15 M/T street radials. my intake is a mopar m1 tunnelram with 2 carter 750 carbs.I am using a comp cams 305-525 hydraulic cam. In my car it ran circles around my mopar 292-509 cam. I made my frist pass with it in my 73 dart last weekend. but i have a converter that is stalling over 5200 right now. so i think there might be some more in it. here is my fastest pass of the night. 60 ft- 1.6483 330- 4.8464 1/8 et- 7.5760 1/8 mp- 90.05 1000 et-9.9467 1000 mph-102.02 1/4 et-11.8555 1/4 mph-110.02 this same engine in my old 65 plymouth with a no name 3500 stall i have dipped into the 11.70 at 113 mph. Now i dont know if your car will run the same as mine but our car combos sound real close to being the same. best of luck to you on your goal. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#380864
07/21/09 03:06 AM
07/21/09 03:06 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
wow ron my car sounds like a slug compared to yours.my engine i just used parts i had laying around. it is a stock bore 73 block, junk home ported heads and a set of 440 six pack pistons out of a 70 440 cuda. ron how does your car drive on the street with the 4200 stall converter?i will be getting a 3800 stall turboaction for mine and thinking about getting the mopar 296-557 solid cam for mine. Thanks Mopar65
I use the Dynamic 9.5 street/strip converter that will flash about 4200 on launch and it drives like a normal converter in the car for street driving. Thats why I like it so much. I have put alot of street miles on this converter as I love how it drives and feels like a normal converter. My 63 has a very nice idle with the .557 cam and the car drives very nice. Thanks for the kind words. Ron
[Re: 383man]
#380865
07/21/09 06:26 PM
07/21/09 06:26 PM
Hi Bobby! Like Ron,I REALLY like my 9.5" Dynamic! When I put in the new cam last spring,the flash stall jumped from 4200 to 4600! And on the street,very docile! You'd never guess it was that high of a stall when driving normal,which isn't very often! As far as cams go,I recommend an SQ lobe Comp solid. Really woke up my .040 over 440! RandyB
