Re: Battery charger testing
[Re: JandJ_Racing]
#380797
07/20/09 11:36 AM
07/20/09 11:36 AM
Well the REAL question is, did it pass or fail?
[Re: JandJ_Racing]
#380798
07/20/09 11:39 AM
07/20/09 11:39 AM
Posts: 2,273 Greenville, South Carolina
BBLM23
I have witnessed that test being done, never did that test myself...
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
#380799
07/20/09 11:50 AM
07/20/09 11:50 AM
Posts: 981 Way North Illinois
JandJ_Racing
Way North Illinois
Jury is still out
[Re: JandJ_Racing]
#380801
07/20/09 12:18 PM
07/20/09 12:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That is funny.... I have seen others doing the same testing before. I did a similar test with my timing light... at the launch it dropped down to the ground but maintained its hook up on the plug... needless to say..... it failed the test procedure... I purchased a single wire unit since and have not tested this one in the same test method........ YET
[Re: MR_P_BODY]
#380802
07/20/09 12:47 PM
07/20/09 12:47 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
I use a 20 inch fan to blow on my oil pan and converter to cool things down. After running over two of them they seemed to have learned to move out of my way.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: Locomotion]
#380805
07/20/09 02:29 PM
07/20/09 02:29 PM
JandJ_Racing
Way North Illinois
I have done similar tests on battery chargers I've had over the years. "Unfortunately", I have found that the weak links are the charger's connection clips. They were not strong enough to remain clamped onto the charging lugs on the car for very long.
Several comments were made on the clamps ability to not let go amongst the onlookers, I guess they didnt understand that this was a scientific testing procedure
[Re: BBLM23]
#380810
07/20/09 09:31 PM
07/20/09 09:31 PM
Posts: 16,928 NC
440Jim
NC
I run an alternator and don't charge between rounds. Or even on a 3 day weekend of racing. Not running the cooling fan an excessive amount is the key.
