Re: need help with figure out what converter stall speed!!!
[Re: mopar65]
#380781
07/20/09 12:35 PM
07/20/09 12:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thanks for the link going by the info i put in it my conv slip % is 9.96503
is that good or bad? thanks Mopar65
I'm sure your spending to much time under the stall point to give you those slippage numbers... as a rule you need to stall about what the peak torque is and shift about 1500 rpm above that so when it drops the rpm its not going much (if any)below the stall point (this is for a race set up)
[Re: mopar65]
#380783
07/20/09 01:10 PM
07/20/09 01:10 PM
MR_P_BODY
Doing the stall from a small roll and in high gear is actually better(you have less ratio to spin the tires to get a better reading). You have either too much stall or you need to move the shift point up much higher(and you might not be able to do that with the cam, heads etc.,etc) it would be nice if you knew what your peak torque rpm is. The 60 is slightly slow but not bad.... which could be with all the low end slippage of the converter
[Re: mopar65]
#380784
07/20/09 01:38 PM
07/20/09 01:38 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Generally Convertors are very torque sensitive,not horsepower. I've tried one of our SS/AH convertors in my 700tq wedge and stalled at 7600. AH motor makes power 1500 rpm higher than my wedge. Of course the starting line spectators thought I broke, but it just flashed on the chip and made me look stupid. Get a nice one made for the car, Turbo Action is fine no need for spendy race convertor. Avoid cheap ones from places and people unknown. Plenty of guys right here.
The little old lady from Pasadena is back!
[Re: MR_P_BODY]
#380785
07/20/09 03:30 PM
07/20/09 03:30 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
thanks for the help guys. mike my car seemed like it was done pulling after 6200 rpm. I think when i ran my best pass the 11.85 was shifting 5900-6000. I tryed shifting over 6200 but the car did not like it. But i was haveing carb ing issues that night allso.this same engine in my old 65 plymouth. with everything the same except my 65 had a no name 3500 stall, 430 gears and 30x9 slicks would run 9.90 at 105 in the 1000 ft.my best pass in my dart was a 9.94 at 102.my best 1/8 in the 65 was a 7.45 at 91 and my dart was a 7.57 at 90.3. my best 60 ft in the 65 was a 1.53 I rememberd that my 65 ran great with the 3500 stall. so i thouhgt my dart would run fine with the soposed 3800-4200 stall that it thought i bought.which my dart might run better if i can get my topend miss figured out.thanks Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#380786
07/20/09 03:52 PM
07/20/09 03:52 PM
MR_P_BODY
You need to remember that its a torque converter... as the torque goes up so does the stall point and if that converter was built for a SB and you put it behind a BB its going to stall more, us SB guys struggle to make torque, not with the BB... its hard to say what the stall differences would be without knowing the differences in the amount of torque and at what RPM for each engine
[Re: mopar65]
#380787
07/20/09 04:06 PM
07/20/09 04:06 PM
Quicktree
hi quick this is going to be a 50/50 car when i say street car i mean nomore than driveing 30 miles one way.i have a stock front end and rear is mopar 002/003 super stock springs and mopar long drag shocks.I bought the converter used off a member here on the board.yes i talked to the member and he said it stalled 38-4200 behine his small block 340.this 440 i have in my car is nothing special so thats why i thought it might work fine for mine. I saw last night that summit sells a 3800-4200 turboaction converter for a 727 what do you think about them? thanks Mopar65
that would probably be a good converter for you but call Paul and make sure 904-741-4850. ask for Paul. I would never buy a SB converter and put it behind BB.
