??? on the 5.9 Magnum #380753
07/20/09 09:58 AM
07/20/09 09:58 AM
GA
Boosted Offline OP
Boosted  Offline OP
GA
I was thinking of picking one of these motors up from the scrap yard but i really would like to make it a carb'd motor with a pretty decent camshaft. Anyone convert one of these motors over to a carb and put inan aftermarket camshaft in? How do they run? I was thinking also about putting the od tranny in the dart also....
Any thoughts and opinions are welcomed and appreciated.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: ??? on the 5.9 Magnum [Re: Boosted] #380754
07/20/09 10:17 AM
07/20/09 10:17 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
I'll let you know if I can get mine running. Take care.
Re: ??? on the 5.9 Magnum [Re: OrangeProwler] #380755
07/20/09 10:19 AM
07/20/09 10:19 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I've got a mopar crate magnum in a car I just bought. I haven't driven it yet but its the 380HP magnum crate which I think is just a regular magnum with a good roller and M1 intake. I don't think the heads are anything special and it has 9:1 cr.
380 sounds high to me though.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: ??? on the 5.9 Magnum [Re: Boosted] #380756
07/20/09 10:25 AM
07/20/09 10:25 AM
scratchnfotraction Offline
yep,all the old LA front fits on the engine
you need to swap in a long nose roller cam,and a flat tappet will work with the right push rods,to run a mech fuel pump
you will need valve spring with the cam swap..stock wont take much..GM3100 v-6 springs and retainer IIRC
a new intake with the correct bolt angle
and carb
the old LA dizzy will fit and same headers
the old tranny fits with the right flex plate set up
just swaping on an intake and headers makes a good improvement on them with a stock engine
IIRC there is a felpro vc gasket that can use the 5 bolt vc on the 10 bolt mag head also
well worth the effort,IMO
I run a pre-mag roller cam 360 headed 318,all stock and a Voodoo cam
worth it to just go roller cam,IMO
Re: ??? on the 5.9 Magnum [Re: CJK440] #380757
07/20/09 10:43 AM
07/20/09 10:43 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
380 horse crate motors regularly dyno 380-410 on an engine dyno....
your cheapest way for getting more cam in there is to get yours reground. contact bulletcams.com about regrinding yours. I just had them regrind the roller cam in my '86 roller motor (I put magnum heads on it). I used the HR259/316 lobe on both the intake and exhaust for my 318. if you want a little rumble/higher RPM powerband, I'd probably look up to the HR273/316 lobe. about .320" lobe lift is the max you can look at without some expensive head work to get more installed height or spring travel before coil bind and seal to retainer clearance. regrind plus shipping there and back was less than $200.
to run a mechanical fuel pump you'll have to swap to an LA t-chain cover and accessory drive, and buy the camshaft snout extender from hughes.
to get springs on there that'll work with a fairly aggressive hydraulic roller lobe, you'll want to get some retainers from a couple 2.2/2.5L mopars in the junkyard and run hughes 1110 springs. you'll be limited to ~.520" valve lift before things start hitting (retainers to seals, coil bind, etc).
comp cams makes some retainers in both 7 degree and 10 degree that might work, and get you a little more installed height. they're for LS1 applications. I couldn't wait for them to get in stock at summitracing before I had to get my magnum heads together to investigate and report on them.
a cheaper (if you pull them off of junkyard heads)/ similar cost (if you buy new) alternative is GM 3100 beehive springs, they provide about .030" less coil bind clearance than the hughes springs, though. again, comp makes some retainers for LS1 applications that might gain a little additional installed height with these springs.
intake, the best options are the RPM air gap for magnums, or redrill the heads for LA intakes. I did the latter, since I couldn't use the eddie magnum air gap due to the water outlet location (offset to pass side), I didn't want to use a chinese manifold (professional product crosswind/summit intake) and I already had an LA RPM air gap. I did it on a bridgeport mill, took about an hour at a machine shop that rented shop time out at $15/hr.
2017 Grand Cherokee Overland
Re: ??? on the 5.9 Magnum [Re: patrick] #380758
07/20/09 11:32 AM
07/20/09 11:32 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I've done the conversion also. Some little tips and tricks here and there, PM me if you need help.
This sports a Hughes 1418ALN 520/544 lift, 214/218 @ .050 with a 108 LSA.
I run Hughes 1110 springs with Hughes retainers (1278 I think) on RHS iron heads. I couldn't justifty Edelbrock alum heads for the price (these cost me less than half of the price of the Edelbrocks).
From the top down, it's running a Holley 4160 650cfm, an Edelbrock Air Gap intake, RHS heads, a Hughes cam which I've previously mentioned, Speedpro pistons and rings, stock rods and crank, a Melling oil pump, and MP LA oil pan.
Re: ??? on the 5.9 Magnum [Re: sharpie] #380759
07/20/09 12:57 PM
07/20/09 12:57 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
That sounds like what I am wanting Sharpie.. I can't see that image here at work but will look at it when I get home...
2011 RAM3500
Re: ??? on the 5.9 Magnum [Re: Boosted] #380760
07/20/09 01:36 PM
07/20/09 01:36 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Unfortunately, it's not a finished picture. I actually don't have one of those yet, lol. If you can get to photobucket, here's a link to the video of how it sounds. Bad audio, but you'll get the idea. It's through Hooker Comp headers and the A-body 2.5" summit exhaust:
http://s7.photobucket.com/albums/y251/sharpie1k/videos/?action=view&current=DSCN4041.flv
Re: ??? on the 5.9 Magnum [Re: Boosted] #380761
07/20/09 06:42 PM
07/20/09 06:42 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I just fired mine up last weekend on my dart.
one thing you want to find is a 99 or earlier motor. the reason is 2 piece harmonic balancer and pulley set up. You will also need the fly wheel with the weights as they are externally balanced. I went the with clearwater heads drilled for the la intake manifold. Lot more options there and they were under 400 a piece, with the correct springs for my cam. I have a mp cam in it and hooker headers for a abody. word of advice if you are putting it in a abody go with exhaust manifolds as it will make it easier to get to put the mini starter in. Do not get the chrome oil pan for the car as it will probably not seal right. professional product manifolds are junk, I got one sitting in my garage right now that I took off due to not sealing properly.
good luck with your swap and if you have any questions pm me and I will see what advice I can give you.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: ??? on the 5.9 Magnum [Re: blk00rt] #380762
07/20/09 07:50 PM
07/20/09 07:50 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
the mini starter will work fine in there with headers, but the headers have to go on after the engine's set generally in place and the starter should go in before the engine's even hoisted off the ground. That means between the stand and the car, bolt the transmission on and the starter.
The headers go in from the bottom (make sure the oil filter's off, pass. side won't fit with it on there). The problem is, the starter may not come OUT that easily. The good thing about Hooker Comps is that the Summit kit bolts right to them.
Re: ??? on the 5.9 Magnum [Re: sharpie] #380763
07/20/09 08:05 PM
07/20/09 08:05 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
yeah thats what I did with my dart, used the hooker headers and the summit kit. the starter will go in but you may have to put heat wrap on it as it is very close to the headers.
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: ??? on the 5.9 Magnum [Re: blk00rt] #380764
07/20/09 08:19 PM
07/20/09 08:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Mini starters go on real easy with the TTIs in my 68 cuda. It is not real close to the tubes and never gave me any trouble restarting after a good heat soak or lots of highway miles even in 100 plus weather I have had experiance with other headers and A-bods and say either use TTIs or manifolds
Re: ??? on the 5.9 Magnum [Re: Boosted] #380765
07/22/09 10:28 AM
07/22/09 10:28 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
What are people's opinions
on a reasonable price to pay for
a Magnum 5.9V8
from a salvage yard
with appropriate $ adjustments for mileage on the engine?
Re: ??? on the 5.9 Magnum [Re: 360view] #380766
07/22/09 05:35 PM
07/22/09 05:35 PM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
i payed $450 for mine with a rebuilt 518 and all the wiring and computer from a private sale, motor has around 110,000 miles. JY's wanted $800 4 just a motor like that but they are crooks in my area. I got to hear the motor running before i bought it too, i thougt it was a good deal
Re: ??? on the 5.9 Magnum [Re: 360view] #380767
07/22/09 06:03 PM
07/22/09 06:03 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I let a 5.9 go last year that needed a rebuild, I got like 75 bucks for it.
it was long block minus distributor
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: ??? on the 5.9 Magnum [Re: Boosted] #380768
07/23/09 07:51 PM
07/23/09 07:51 PM
Frederick, MD
moparguy1967 Offline
Frederick, MD
I found my 2001 magnum 360 on the website below. It had 12k mile for $650. I was even able to hear it run before they pulled it.
www.car-part.com/
I just got to drive it for the first time last night. Ran pretty good for a stock truck motor. I need to rejet my demon carb, other then that it all good.
Re: ??? on the 5.9 Magnum [Re: moparguy1967] #380769
07/23/09 08:09 PM
07/23/09 08:09 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Best small blk combo's, factory .430/.444" 340 hp cam, 4 speed, and 3.23 gears. Set up with headers, and a performer manifold, it will have spirited performance in all situations.
Been experimenting on releasing spring pressure with moderate cams. The GM V6 beehive spring may take back some frictional losses due to a lighter seat pressure. If you drive it avoid heavy springs at costs.
Re: ??? on the 5.9 Magnum [Re: moparguy1967] #380770
07/23/09 11:34 PM
07/23/09 11:34 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Looks great I think you will be really suprised on how well a pickup truck motor runs with the intake & exhaust opened up- considering it can idle at 500rpm with 21" of vac.
Re: ??? on the 5.9 Magnum [Re: Boosted] #380771
07/24/09 12:33 AM
07/24/09 12:33 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
The 5.9 has a shorter deck height then the 360 by .020, 9.58" vice 9.60", keep this in mind when squaring the block. You can have it taken down to 9.56" safely.
For a Center Sump Oil Pan you can use Mopar P5249059. This kit included Pan, Dip stick, Dip stick tube and Oil Pump Pickup.
.020 is cleans the cylinders up good, and utilizing Speed Pro Hyper ZH116CP20 pistons will give you anything between 9:1 to 10:1 depending on the Heads that you use. The skirts are coated also to make them a little more slick.
The Stock rods are good for 400HP or 7000 RPM, but if you think you need stronger one MOPAR has forged rods. The heavy duty rod is P5239745 and the "Light" (Racing)forging is P5249740.
One of the big advantages of using the Magnum is the "Roller Cam" set up. You can have the one in it motor reground, which will require different push rods to correct the geometry or use the MOPAR Crate Motor Cam shafts
P5249663 is a .385"/.401" Lift 250/264 Duration and a 108 center line
P4876348 is a .501"/.513" Lift 288/292 Duration and a 108 center line.
While the lifts are not that radical, keep in mind that these are "Roller" grinds which have a much steeper Ramp angle over either a flat tappet cam, giving you more "under the curve" dwell time for the valves.
The advantage of using either one of the above cams is that the "Fuel Pump" eccentric is built into these cams where regrinding the one that is in the motor will require an adapter if you plan on using a mech fuel pump.
As stated earlier if you plan on using a "Mech" fuel pump then you will need to find a Timing Chain cover from a "LA" engine.
Head Selection is up to you, Flow Characteristics and Chamber size is what you need to watch... The KEY here is Horse Power is built at the "Top" of the engine not the bottom. Heads, Cam, Intake, and Exhaust.
RyanJ from Shady Dell Speed shop is the expert in this arena.
Magnum R/T Big Valve Heads (Cast Iron)
Hughes Iron Ram Magnum Heads (Cast Iron)
EQ (Engine Quest) Heads (Cast Iron)
Edelbrock Magnum (Aluminum)
Head Gaskets Mopar P4876048 are a good 4.06" bore gasket with a .040"-.042" Crush height and are good to 12 to 1 compression. ~$35 a set. You need to watch the bore size!!!!
While both the 360 and 5.9 are externally balanced the balance weight is different. Basically what this means is that you will need to use a different weight set on you torque converter if your planning on using a "LA" Trans (i.e 727,904). Another way around this is to use the B&M Flex Plate BMM-10241 which is correct for the Magnum which allows the use of a "Neutral" balanced converter.
Hope this helps.
Summary. The 5.9 Magnum with the correct parts can easily make 400 "Streetable" horsepower in a durable package.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: ??? on the 5.9 Magnum [Re: Noblewk] #380772
07/24/09 08:37 AM
07/24/09 08:37 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I've got a 380HP crate that I have yet to "test".
I think it uses stock magnum heads. The newer 390HP crate uses big valve R/T heads but only nets 10hp more.
I suppose it has to do with the low cam lift not letting the big valve heads get into their zone???
