One thing after the other,....Crankcase Evac Valves?
#380715
07/20/09 08:36 AM
07/20/09 08:36 AM
Posts: 4,573 ...gently down the stream
LAR_414
It seems like after I fix one thing, something else goes out. Nothing major, but does it ever end?
Anywho,...both of my Mr. Gasket crankcase evacuation check valves are gone. I guess I've had them on the car for about 4 years, so I can't complain, but I thought they would last a little longer.
I remember some discussion a while back, on these things blowing out, and there are apparently better ones out there. Can someone help me out here? I've got the system capped off for now, but I would like to eventually hook it back up.
By the way, if anybody is wondering,...I've got the car up an running from my blown out head gasket, and all seems well.
Thanks, Larry
Re: One thing after the other,....Crankcase Evac Valves?
[Re: LAR_414]
#380720
07/20/09 11:27 AM
07/20/09 11:27 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Another thing I like to do with the valve is to move it a little farther away from the collector to help keep it cooler(where you thread the valve on if need be add some pipe fittings to move the valve away)
