Explain how cross talk works
#380463
07/19/09 09:27 PM
07/19/09 09:27 PM
Posts: 916 Arizona
Chucklehead
Arizona
How does it work and why do you use it?
Still Broke
Re: Explain how cross talk works
[Re: 68roadrunner]
#380469
07/20/09 06:33 AM
07/20/09 06:33 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I have never used a delay box. Can someone explain how you can hit the tree more than once? Will the box turn off if you press the button again and act like it would with no brake and leave when you lift off the button again on the last bulb?
[Re: Evil Spirit]
#380472
07/20/09 07:25 AM
07/20/09 07:25 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
can we go back to the 5 bulb tree, so i can hit it that many times.
Or go to a pro tree, and leave all the electronic crap in video games where they belong.
BINGO!!!! we have a driver.
[Re: BDS871Cuda]
#380474
07/20/09 09:17 AM
07/20/09 09:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you guys are good, what do you care if the other guy uses a box.... I like them ..... JMO
[Re: bonefish]
#380477
07/20/09 10:54 AM
07/20/09 10:54 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
That sounds good on paper but it would cause some problems as well. If you stage your Roadrunner, Cuda, Dart, etc., against a dragster or tube chassis car on a pro tree..... you are going to get waxed on a steady basis.
Lighter cars and non suspended cars will react much quicker than a typical back halved or leaf sprung bracket car. I like the IDEA of a pro tree also, but it's a lot more complicated than that.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: 71cuda]
#380480
07/20/09 12:04 PM
07/20/09 12:04 PM
MR_P_BODY
the problem i have with cross talk is i'm a footbraker,proclass no electronics.when i go into super pro if i'm the faster car it really screws up reaction time.top bulb stays on awyhere from 1-2 seconds the drops.running that class with out a box is hard enough without having the tree screw with you.
I dont know if all tracks do it BUT put a N on your windshield for "no cross talk" this wont get you the top light popping on till its for your side of the tree
