2002 caravan starting problems #380414
07/19/09 08:31 PM
07/19/09 08:31 PM
Ohio
P
pengwin Offline OP
pengwin  Offline OP
P
Ohio
We've got a 2002 3.3 v6 Grand caravan that we've had starting issues with for almost a year now. It turns over just fine, but doesn't want to fire. The dealer had it and replaced the PCM, fuel pump, and the coil pack. It ran OK for a very short while, but now it's a crapshoot every time we try to start it. Sometimes it fires right up, sometimes it takes 10-15 tries. There seems to be no ryhme or reason why sometimes it starts right up and other times it doesn't. Help!!!
Re: 2002 caravan starting problems [Re: pengwin] #380415
07/19/09 09:05 PM
07/19/09 09:05 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
first I would bring it back because they didn't fix it the first time....any check engine light or did u check for any codes?
Re: 2002 caravan starting problems [Re: AARCONV] #380416
07/20/09 08:19 AM
07/20/09 08:19 AM
Ohio
P
pengwin Offline OP
pengwin  Offline OP
P
Ohio
The codes are P1684,0352,0351 and 0350, which are the same as before I had it serviced.
