67 gtx wheel question- magnum 500 15 x 8?? #380288
07/19/09 05:48 PM
07/19/09 05:48 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
Hi, I have 15 x 7 now with 275 60 15 ta's. They are pulled in quite abit and would like a little wider wheel. What back spacing should I be looking for. I believe my 15 x 7 have a 4 1/2 back space. thanks
1971 340 Swinger Canadian Car
1972 Dodge Dart Prostreet 440
2013 Dodge Ram 1500
Re: 67 gtx wheel question- magnum 500 15 x 8?? [Re: dalei989] #380289
07/19/09 06:30 PM
07/19/09 06:30 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm surprised 275's will fit in a 67 fenderwell. on a 15x7, I believe 4-1/4" backspace puts it centered in the well. So if you go to 15x8's, I'd look for a 4-3/4" b.s. (just split the difference).
Re: 67 gtx wheel question- magnum 500 15 x 8?? [Re: dalei989] #380290
07/19/09 06:32 PM
07/19/09 06:32 PM
I'm running 15x8 with a 4 1/2" back space and 275/60's under the back of my 67' R/T, but..... My wheel well lips are rolled in.
Re: 67 gtx wheel question- magnum 500 15 x 8?? #380291
07/19/09 07:02 PM
07/19/09 07:02 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
My wheel well lip are still stock and I don't want to roll them. Thinking of trying to find a 15 x 8 with 5 inch back spacing and then if I need to use a small space to kick it back out and can. thanks
2013 Dodge Ram 1500
