Torque and HP curves #380275
07/19/09 05:34 PM
07/19/09 05:34 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
What's wrong here ? Aren't the curves supposed to cross at 5252 rpm ??
Re: Torque and HP curves [Re: Wedgeman] #380276
07/19/09 05:58 PM
07/19/09 05:58 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The RPM scale on the X-axis makes sense for HP but it's totally wrong for the torq. No way does a 360mag only make 80ft-lbs of tork at 5k rpm. Whoever made that graph doesn't have a clue what they're doing. Never mind the torq and hp using different scales for some reason, that makes no sense either, no reason to do that for a motor that makes not a huge amount more torq and hp.
Re: Torque and HP curves [Re: DaytonaTurbo] #380277
07/19/09 09:41 PM
07/19/09 09:41 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
THis is a graph from bionicdodge.com......
Tork is dropping amazingly fast down the curve...
I think it is bogus too......
Any other comments ?
Re: Torque and HP curves [Re: Wedgeman] #380278
07/19/09 09:50 PM
07/19/09 09:50 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
There's something goofy here. Engine dynos measure torque, the horsepower is calculated from the torque and speed at that torque reading. ASSUMING the torque units are foot-pound, if you take the torque peak of 330 foot-pound at 2000 rpm, the equation is 330*2000/5252 = 126 Hp which is radically different from the curves.
Re: Torque and HP curves [Re: 6PakBee] #380279
07/19/09 10:09 PM
07/19/09 10:09 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Good point ! and reliable answer.....
Now where to find correct curves ?
Daniel
