4 pointer to six, what are the rules #379561
07/19/09 08:57 AM
07/19/09 08:57 AM
Milwaukee, WI
joflaig Offline OP
joflaig  Offline OP
Milwaukee, WI
I have a 4 point roll cage, with bars going into the trunk. I am thinking about going to 6, with 2 along the doors. Am I allowed to use rings to attach the main segments to the existing cage or must they be welded at that juncture? This would be for something going low 11s, but I am thinking ahead to a day when I may make the changes for high 10s.
Also, I've seen many cages with two extra supports under the horizontal bar behind the seats. I can see the pros in that, but what are the rules? The cage is painted so I'm trying to see what I can do without having to weld and re-paint. Thanks.
Re: 4 pointer to six, what are the rules [Re: joflaig] #379562
07/19/09 09:27 AM
07/19/09 09:27 AM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
NHRA 5 point is all you need down to ten flat,just need the door side bar, if you have unaltered floor and firewall...Swingout door bars are good to lower than that I believe.. That being said when my car hit 11:5's I did an 8 point with the diagonal supports you mentioned tied into the subframe connectors.I wanted to stiffen it up a bit... the link gives tubing size and diagrams. You have to weld the door bar/swingout mount to the main hoop and land the floor attachment on a 6x6x1/8" plate, the plate can be bolted to the floor but the bar/swingout mount has to be welded to it...99% sure.. Bar rule
Re: 4 pointer to six, what are the rules [Re: Gary67] #379563
07/19/09 10:57 PM
07/19/09 10:57 PM
nebraska
roadrunner470 Offline
nebraska
What is meant by modified floor pan or firewall? I have subframe connectors welded into my floor and patched rusty places in the firewall. Does this fall into medifications or do they meaning moving the firewall and such.
Re: 4 pointer to six, what are the rules [Re: roadrunner470] #379564
07/19/09 11:58 PM
07/19/09 11:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Subframe connectors & firewall patches won't be a problem with Tech.
If you go with a 6-point, tie the hinge pillars into it and run a bar between the hinge pillars and the shock towers.
Re: 4 pointer to six, what are the rules [Re: topside] #379565
07/20/09 09:13 AM
07/20/09 09:13 AM
nebraska
nebraska
What do you mean by hinge pillar? I am very uneducated on cages.
Re: 4 pointer to six, what are the rules [Re: roadrunner470] #379566
07/20/09 03:48 PM
07/20/09 03:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The hinge pillar is what the door hinges attach to; big boxed vertical panel. Major part of unibody stiffness.
Re: 4 pointer to six, what are the rules [Re: topside] #379567
07/21/09 12:49 AM
07/21/09 12:49 AM
nebraska
nebraska
Ahh that is what I thought. What is the bar called that runs along the roof then meets with the door bar.
Re: 4 pointer to six, what are the rules [Re: roadrunner470] #379568
07/21/09 07:23 AM
07/21/09 07:23 AM
alabama
mopars rule Offline
mopar addict
mopars rule  Offline
mopar addict
alabama
halo
