Header Tube Size???-440-1 Heads
#379457
07/19/09 12:18 AM
07/19/09 12:18 AM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
i am just about done building my 572ci Indy Maxx motor for my 63 Dart...the headers are going to be custom built and need to know what you guys think about header tube size..i have a set of 440-1(345cc)CNC'd,747/765 roller cam,14.0CR,single 1250 Dominator for now but will be installing my Tunnelram later..i didnt know if 2 1/8" is going to be enough tube or if i need to go to the 2 1/4" ??? Oh, before i forget, when i do upgrade the motor in a few seasons, i will be boring the motor to 4.5" and making 604ci at that point.. spending 1500 on a set of custom headers is something i really only want to do once..so if i go with the 2 1/4 tube now is that going to hurt me?? what are you guys using ???
Re: Header Tube Size???-440-1 Heads
[Re: BILLYJAY]
#379458
07/19/09 12:32 AM
07/19/09 12:32 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I went 2 1/8 by 30 inch with a 4 inch collector, but you might go to 2 1/4 and have as good results, seeing as you have more cubes. If you are having to bend the tubes down right after the flange, might be worth going to 2 1/4. Mine go up instead of down. Now that i reread the post, definitely 2 1/4 for the big motor. I doubt you will take much away from the 572, especially if you run a loose converter.
[Re: rebel]
#379461
07/19/09 07:01 AM
07/19/09 07:01 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I agree with Greg. With 572 inches a 2 1/4 will fit the bill. I run 2-1/8 stepped to 2-1/4 with 557 inches. They seem to be about right for my combo. With the cost of custom headers I wouldn't want to build them twice. I have $1300 in the headers and another $600 in collectors
[Re: Bigcube]
#379463
07/19/09 09:06 AM
07/19/09 09:06 AM
Posts: 16,930 NC
440Jim
NC
x2 Keep them short (30-32") and a 4" collector should be good.
My little 511 CID has 2-1/8" x 32 headers.
[Re: BILLYJAY]
#379466
07/19/09 03:00 PM
07/19/09 03:00 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i just dyno'ed my 580" motor.the test headers were 2" to 2 1/8 with a 3 1/2" collector.then i tried my headers that i will use in the car.they are custom kooks 2 1/8 to 2 1/4 with a 4" collector.my bigger headers made the exact horsepower and 5-6 less ftlb of torque.it was a supprise to me......
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#379467
07/19/09 10:31 PM
07/19/09 10:31 PM
BILLYJAY
Mr P-Body..here is the flow sheet you needed.. IT IS ATTACHED!!!!! the rest of the info i will have tomorrow...
