Header Tube Size???-440-1 Heads #379457
07/19/09 12:18 AM
07/19/09 12:18 AM
Lake Charles,Louisiana
BILLYJAY Offline OP
BILLYJAY  Offline OP
i am just about done building my 572ci Indy Maxx motor for my 63 Dart...the headers are going to be custom built and need to know what you guys think about header tube size..i have a set of 440-1(345cc)CNC'd,747/765 roller cam,14.0CR,single 1250 Dominator for now but will be installing my Tunnelram later..i didnt know if 2 1/8" is going to be enough tube or if i need to go to the 2 1/4" ??? Oh, before i forget, when i do upgrade the motor in a few seasons, i will be boring the motor to 4.5" and making 604ci at that point.. spending 1500 on a set of custom headers is something i really only want to do once..so if i go with the 2 1/4 tube now is that going to hurt me?? what are you guys using ???
Re: Header Tube Size???-440-1 Heads [Re: BILLYJAY] #379458
07/19/09 12:32 AM
07/19/09 12:32 AM
gregsdart Offline
gregsdart  Offline
I went 2 1/8 by 30 inch with a 4 inch collector, but you might go to 2 1/4 and have as good results, seeing as you have more cubes. If you are having to bend the tubes down right after the flange, might be worth going to 2 1/4. Mine go up instead of down.
Now that i reread the post, definitely 2 1/4 for the big motor. I doubt you will take much away from the 572, especially if you run a loose converter.
Re: Header Tube Size???-440-1 Heads [Re: gregsdart] #379459
07/19/09 12:39 AM
07/19/09 12:39 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i haven't got as many cubes as you but i'm building my own custom headers. was up till 11.30 last nite welding these together. 2" primaries stepping up to 2 1/8" before going into 3 1/2" slip on merged collectors. they're not long tubes by anymeans & we don't have to run muffs. still have to weld on the pyro mounts & the CC extractor flare but i feel these babies when finished will help my gases flow & maybe nett me a few more ponies.
Re: Header Tube Size???-440-1 Heads [Re: rebel] #379460
07/19/09 12:41 AM
07/19/09 12:41 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
another angle. sorry pics aren't too clear. pics taken on cellphone than was getting flat
Re: Header Tube Size???-440-1 Heads [Re: rebel] #379461
07/19/09 07:01 AM
07/19/09 07:01 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I agree with Greg. With 572 inches a 2 1/4 will fit the bill. I run 2-1/8 stepped to 2-1/4 with 557 inches. They seem to be about right for my combo.
With the cost of custom headers I wouldn't want to build them twice. I have $1300 in the headers and another $600 in collectors
Re: Header Tube Size???-440-1 Heads [Re: BILLYJAY] #379462
07/19/09 08:35 AM
07/19/09 08:35 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
i chose to go 2 1/4 x 4 for the 440-1 headed 540...thinking they'll be big enough to handle a procharger when that time comes.
Re: Header Tube Size???-440-1 Heads [Re: Bigcube] #379463
07/19/09 09:06 AM
07/19/09 09:06 AM
NC
440Jim Offline
440Jim  Offline
NC
x2
Keep them short (30-32") and a 4" collector should be good.
My little 511 CID has 2-1/8" x 32 headers.
Re: Header Tube Size???-440-1 Heads [Re: BILLYJAY] #379464
07/19/09 09:44 AM
07/19/09 09:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you send me a PM I cant run your engine through
my header program for you
Re: Header Tube Size???-440-1 Heads [Re: MR_P_BODY] #379465
07/19/09 11:05 AM
07/19/09 11:05 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Thanks guys for the Good Info.. Mike, I sent you a PM...
Re: Header Tube Size???-440-1 Heads [Re: BILLYJAY] #379466
07/19/09 03:00 PM
07/19/09 03:00 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i just dyno'ed my 580" motor.the test headers were 2" to 2 1/8 with a 3 1/2" collector.then i tried my headers that i will use in the car.they are custom kooks 2 1/8 to 2 1/4 with a 4" collector.my bigger headers made the exact horsepower and 5-6 less ftlb of torque.it was a supprise to me......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Header Tube Size???-440-1 Heads [Re: Old School] #379467
07/19/09 10:31 PM
07/19/09 10:31 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Mr P-Body..here is the flow sheet you needed.. IT IS ATTACHED!!!!! the rest of the info i will have tomorrow...
