Oxygen sensors....?
#379201
07/18/09 06:17 PM
07/18/09 06:17 PM
Posts: 196 West Central Indiana
Mr.Runum
Do Oxygen sensors go bad gradually or, do they either work or they don't? 02 Ram 2500 4x4 has a slightly rough idle when warmed up and has had a recent tume up. Also MSD (ignit, coil, plug wires) shorty headers, K&N, Superchip. Any other thoughts?
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
Re: Oxygen sensors....?
[Re: Andrewh]
#379203
07/18/09 09:22 PM
07/18/09 09:22 PM
Mr.Runum
Not geting a code yet but, could it be going bad and not give a code? If I had a code come up I can read it with the superchip and I have a code book. Problem could still be ignition, been eating cap and rotors. Installed cap & rotor with brass instead of aluminum electrodes.
Mr.Runum
[Re: NITROUSN]
#379206
07/18/09 11:35 PM
07/18/09 11:35 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Intake plenum gasket leaking.
Might be worth checking. Recent MA article by E-berg talked about this very thing. Symptoms were
"lousy idle, stalling, high oil consumption - leading to detonation damage and lots of carbon. How to test (engine installed and running)? Disconnect PCV hose, plug the hose and cap the nipple. Plug any and all make-up air hoses/caps (breather). Remove the oil cap and place your palm over the hole (engine at idle). Feel any vacuum (suction)? The gasket is shot."
I've also heard - don't know for sure - that you can look down through the throttle body (engine off) with the throttle plates open to look for oil residue on the plenum base. Oil means the gasket is shot.
