Re: Hughes Rocker Arms [Re: Moparnut426] #379187
07/23/09 04:32 PM
07/23/09 04:32 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I have heard Hughes are accually Probe rockers, and If Im spending what they want for a non roller fulcrum and I have big money in my heads/engine, Ill spend another $200 and buy the Harland SHarps. I can get a set for my Brodix B1BA small blocks heads with an offset back shaft set up for large springs from Harland for $850. I have to save fo an extra 2 months, but I should be worry free for a LONG TIME!!!
Nothing wrong with the Hughes stuff, just dont like the fact they dont offer a bearing fulcrum.
Kasey
What worries me about needle bearing fulcrums is that there are more parts that could potentially fail. I have seen in two cases the races broke apart. Lot of parts that could fall out and distribute themselves through various parts of your engine. Has this happened to anyone else?
Re: Hughes Rocker Arms [Re: Moparnut426] #379188
07/23/09 04:47 PM
07/23/09 04:47 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
If I told you I was a pilot, are you 99% sure you would get in a plane with me?
Re: Hughes Rocker Arms [Re: S/ST 3040] #379189
07/23/09 05:53 PM
07/23/09 05:53 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Yes
Re: Hughes Rocker Arms [Re: knyech1] #379190
07/24/09 01:44 PM
07/24/09 01:44 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have wondered about the bearings failing, But in my research I have only found a failure when something else major fails, Keeper breaks, and the valve get impacted by piston, this hitting rocker arm with a mess, the timming chain breaks and a valtrain failure that way, I havent ever heard of a fulcrum bearing just failing, maybee an oil restriction, but I have asked many guys, and many different engine builders who havent ever heard of that. I do like the fact that with Jessel stuff the shaft is smaller, thuss the bearing is smaller whick in theory makes for less stress on the bearing. I have definate trust in the Harland stuff from seeing some of the spring PSI on some large CI mopars. Im also currious if anyone on here has heard of any other plain jane Harland sharp failures....
Re: Hughes Rocker Arms [Re: Moparnut426] #379191
07/24/09 02:07 PM
07/24/09 02:07 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... Im also currious if anyone on here has heard of any other plain jane Harland sharp failures....
Yep. Dwayne Porter has mentioned seeing HS failures (more commonly for small-block than big-block, IIRC).
I don't think Joe Average needs needle-bearing fulcrums w/ a pressurized shaft rocker system. Needle bearings are applicable to applications that rely on oil splash / mist for fulcrum lubrication. A plain bearing setup on a pressurized shaft distributes the load better than needle bearings, even if it doesn't look as sophisticated.
Re: Hughes Rocker Arms [Re: Moparnut426] #379192
07/24/09 02:55 PM
07/24/09 02:55 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
All the pressure and shock in the valve train is concentrated on 1 or 2 needles at the most.
Direct from Hughes web sight: http://www.hughesengines.com/TechArticles/503rockerarms282007.php
Re: Hughes Rocker Arms [Re: BradH] #379193
07/24/09 10:19 PM
07/24/09 10:19 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We ran stock OOTB Crane gold rockers with a UltraDyne .613 cam and the suggested springs and never had a problem,and they had been used for 5 race seasons before that.
Nautilus Racing-
Re: Hughes Rocker Arms [Re: Chris2581] #379194
07/24/09 11:27 PM
07/24/09 11:27 PM
I put a set of Hughes rockers (supplied by the customer, because he was "on a budget") on a customer's motor and they lasted about 6 passes before one of the pins that holds the roller in came out, which let the roller fall out, and then the rocker was beating on the keepers until they came out and it dropped a valve...........That pin is just pressed in, unlike a Harland Sharp, which is screwed in......
So now, I've got a customer bad mouthing me because I charged him to fix it, and he even got a new rocker and valve for free from Hughes.........
Learned my lesson on that one........
Re: Hughes Rocker Arms #379195
07/25/09 01:07 AM
07/25/09 01:07 AM
BradH Offline
BradH  Offline
I'll take a good look at mine when I pull the valve covers to check the lash, but they've got two dyno sessions and a bunch of street & strip miles on them so far w/o any issues. Like I did mention, though, I had to replace a couple before even using them because the roller wasn't spinning freely.
Re: Hughes Rocker Arms [Re: BradH] #379196
07/28/09 10:42 PM
07/28/09 10:42 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Yeah let me know. I might be getting a decent paycheck soon so I am sort of looking to buy. Just gotta check my pennies and see if I will have enough when it is all said and done.
Re: Hughes Rocker Arms [Re: knyech1] #379197
07/29/09 12:21 AM
07/29/09 12:21 AM
SD
4spdJohnny Offline
4spdJohnny  Offline
SD
Have had a set of Hughes rockers on my 451 for 5 years, 15,000 street miles, 600 drag strip passes, who knows how many street beatings. I use nothing else. I have put a dozen sets on customer engines with no problems!
Re: Hughes Rocker Arms [Re: knyech1] #379198
07/29/09 07:04 AM
07/29/09 07:04 AM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
I have a set on a circle track engine that was built by Hughes back in '97, have had no problems with any of his parts,class act all the way around,highly recemend them
