Hughes Rocker Arms #379167
07/18/09 06:03 PM
07/18/09 06:03 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Has anyone tried the Hughes Rockers since they started their CNC program? I am wanting to get a set of rockers for my 340 and was going to go Crane Gold but they are out of business, thoughts??
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Hughes Rocker Arms [Re: knyech1] #379168
07/18/09 07:18 PM
07/18/09 07:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Saw a set of 440 arms and look like a nice piece
Re: Hughes Rocker Arms [Re: knyech1] #379169
07/18/09 08:17 PM
07/18/09 08:17 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Are you sure they actually make these? Most of the things that are "Hughes" brand are actually made by other companys. They like to make it sound like they helped design/makes them...but usually that is not the case. Not that they sell bad stuff....it is usually quality stuff though.
Re: Hughes Rocker Arms [Re: knyech1] #379170
07/18/09 08:23 PM
07/18/09 08:23 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've got a set of the older ones, about six years old. They've held up great, I had to clearence them for this build as RyanJ used a larger o.d. spring than I ran in the past.
Re: Hughes Rocker Arms [Re: justinp61] #379171
07/18/09 09:53 PM
07/18/09 09:53 PM
Oak Harbor, WA
W
Wicked49670dart Online mad
Wicked49670dart  Online Mad
W
Oak Harbor, WA
I used their rockers, shafts and hold down kit. No problems. Rockers assembly is 1.5 years old and 35 runs on them...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Hughes Rocker Arms [Re: Wicked49670dart] #379172
07/19/09 12:56 PM
07/19/09 12:56 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I want to put them in my street/strip car. I would get the shafts, hold downs, and rockers if I were to get them. Are Crane Golds even still available?? What are the life cycles of both?
Re: Hughes Rocker Arms [Re: knyech1] #379173
07/19/09 08:36 PM
07/19/09 08:36 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I dont know anything about Hughes rockers-never heard a bad thing about them.
I saved this interesting pic --Its a Crane gold and a Harland rocker
Re: Hughes Rocker Arms [Re: 493_DART] #379174
07/19/09 08:45 PM
07/19/09 08:45 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
The picture says it all
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Hughes Rocker Arms [Re: 493_DART] #379175
07/19/09 09:12 PM
07/19/09 09:12 PM
Niagara, Ontario Canada
mrpatel Offline
mrpatel  Offline
Thanks, those are mine. I cant believe the differnce in the quality and size between the two. Cranes are probaly fine for low spring presures. I have no info on the Hughes, but I have heard good things. Andrew
Re: Hughes Rocker Arms [Re: mrpatel] #379176
07/19/09 09:19 PM
07/19/09 09:19 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I have not heard anything bad about the hughes, i have some cheap stainless ones on my kids car now, but i have a set of Harland Sharps that are going on the car and i will also be running H.S.
Re: Hughes Rocker Arms [Re: 65signet] #379177
07/19/09 09:25 PM
07/19/09 09:25 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I have used the gold Cranes with all three cam types including a very high pressure solid roller with NO problems. The HS and Hughes are nice. Just my
Re: Hughes Rocker Arms [Re: DaKuda] #379178
07/19/09 10:38 PM
07/19/09 10:38 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Nothing wrong with the Hughes stuff. I've used their rockers before; 660+lbs. open spring pressure w/ no problems whatsoever.
Re: Hughes Rocker Arms [Re: DaKuda] #379179
07/19/09 10:48 PM
07/19/09 10:48 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I am running a .540 solid flat tappet cam. Someone told me a little while ago that the Hughes rockers weren't that good because they weren't very consistent, but he made sure he stated that it was before their CNC program they started, so they may be better now.
I can see that there is more meat and therefore a stringer rocker (all variables thrown out as far as material differences go) but I have heard that the Harland (and Comp Cams) rockers have problems with the needle bearing races on the fulcrum in that they are kind of prone to break. I have even seen it myself in two different cases so that has scared me from Harlands, even though the cams ran were a bit larger than mine and therefore had more spring pressure put on them. Has anyone else had this problem?
Re: Hughes Rocker Arms [Re: knyech1] #379180
07/23/09 10:51 AM
07/23/09 10:51 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I run these rockers on my Challenger. The Hughes CNC rockers are made by Probe Industries. The older ones I bought needed to have the oil feed holes to the rocker adjuster screws connected (i.e. a groove added) to the main oil feed channels to ensure that they were getting lube full time. I also opened up the size of the feed holes because they weren't drilled to a consistent size from one rocker to another.
The latest rockers I've gotten from them now have the first problem corrected, but I'm still going to open the oil feed holes' size to the same as my others. The size of the holes are too small, IMO.
Also, check new rockers closely to make sure the roller tips move freely and smoothly. I've had a problem w/ a couple of rockers where the roller tip was binding, rather than moving smoothly, and needed to be exchanged.
Re: Hughes Rocker Arms [Re: BradH] #379181
07/23/09 11:34 AM
07/23/09 11:34 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Thank you for the input on that. I don't know much about valvetrain oiling. How much bigger should the holes be??
Re: Hughes Rocker Arms [Re: knyech1] #379182
07/23/09 12:50 PM
07/23/09 12:50 PM
BradH Offline
BradH  Offline
I don't recall exactly how big mine are now... probably at least .090". I compared them to Crane and Dove rockers I had around at the time and opened them up to be more like what those were.
Re: Hughes Rocker Arms [Re: SuperStocker] #379183
07/23/09 01:21 PM
07/23/09 01:21 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have heard Hughes are accually Probe rockers, and If Im spending what they want for a non roller fulcrum and I have big money in my heads/engine, Ill spend another $200 and buy the Harland SHarps. I can get a set for my Brodix B1BA small blocks heads with an offset back shaft set up for large springs from Harland for $850. I have to save fo an extra 2 months, but I should be worry free for a LONG TIME!!!
Nothing wrong with the Hughes stuff, just dont like the fact they dont offer a bearing fulcrum.
Kasey
Re: Hughes Rocker Arms [Re: Moparnut426] #379184
07/23/09 01:50 PM
07/23/09 01:50 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i believe the older aluminum roller were probe and i have a set of 1.6 ...
dont know who makes their newer ones.
Tony
70 AARCuda Vitamin C
Re: Hughes Rocker Arms [Re: 70AARcuda] #379185
07/23/09 03:20 PM
07/23/09 03:20 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The old extruded rockers were made by Dove.
Re: Hughes Rocker Arms [Re: 70AARcuda] #379186
07/23/09 03:57 PM
07/23/09 03:57 PM
Moparnut426 Offline
Moparnut426  Offline
Im 99% sure they are probe. I spoke with a rep at probe, asked him if they make the rockers for hughes, he said uuuuummm.....yep.
