Page 80 of 167 1 2 78 79 80 81 82 166 167
Re: New how to paint your car on a budget with a roller [Re: Gusteve] #37894
01/27/08 07:38 PM
01/27/08 07:38 PM
south louisiana
lowell66dart Offline
south louisiana
I'll look back and shoot him a pm. If need be I guess I could spray the hood.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: New how to paint your car on a budget with a roller [Re: lowell66dart] #37895
01/27/08 11:58 PM
01/27/08 11:58 PM
Speaking of spraying the hood...
From what I've read through the numerous threads and compilation websites I've found on this method, I've found that there's about 2 ways to go about door jambs and under the hood, as well as other areas that don't need a lot of attention.
69chargeryeehaa said,
i don't sand/polish the underhood and door jambs, it looks fine just as it is. the wetsanding and buffing is only done for the exterior that you see. it does not look out of place at all, the natural finish looks great, besides those areas such as door jambs are full of curves, ect...and it's hard to even see a difference in finish at all.
Exit1965 said,
For door jambs, engine bays, etc., it is easier to use spray cans or spray the paint on if you have a compressor. I used a compressor and gun to paint my door jambs, and used a refillable rechargable spray can from Harbor Frieght to paint my engine bay. Using one of those refillable cans allows you to get the exact same color since you're using the exact same paint you're rolling with (although it doesn't need to be thinned quite as much).
So what I'm wondering is... What have other people done? It would be a lot easier to just spray the bottom of the hood and I plan on spraying inside the engine bay with some sort of satin black spray anyways... But what about the little L shaped lip around the hood, have people been painting the hood and then opening it to paint that lip and under the hood? Removing the hood altogether?
And as for door jambs, what have you guys been doing? I'm thinking of just using a small foam brush and a roller when I can, and just do the jambs, inside of the door, then outside of the door... And then close the door for wet sanding and open it again for the next coat?
Maybe I'm making things more complicated than they should be, and I should just go ahead an roll the whole exterior out, get it completely finished and then go back and mask off everything but the jambs and under the hood and spray it?
Anyways, please share what order and what methods you guys have been doing these not-often seen areas.
Re: Pics? #37896
01/28/08 01:11 AM
01/28/08 01:11 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Hi Marq!
Having read most of the posts from the very first thread on this subject I feel as if I know a bunch of you already, but it took about a week to get to this point!
Having said that, I (and I suspect many others) would love to see pics of some of the vehicles that were posted two years ago when this thread began but have since been lost because of hosting changes made by the original posters. Your Mustang, for example, is profiled quite a bit but the pictures are no longer available. Would you please repost a few of them? After all the kudos I'd love to finally see it!
Believe it or not... the number of folks who viewed the pics I had posted WERE KILLING MY SERVER. We were chewing up so much bandwidth that I had to take the pics offline so that my regular visitors could make it to my site without suffering massive lag times...
I have attacked some pics to this message and the following messages. Plus a few of the 'BEFORE' pics to let you know what a basketcase this puppy was...
That should hopefully inspire other owners whose cars are looking somewhat dogged...
And just to answer the question before it is asked.... I began by painting the car with Rustoleum/Tremclad Fire Red... and half-way through I switched over and finished with Brightside Fire Red paint.
Enjoy... and thanks for asking.
A nice shot of the McLaren and the Cobra... one went to a pro-paint shop ($3800) and the other was done in my garage with a roller.($250).. ( HINT : the roller job is the shinier one )
Re: Pics? [Re: Marq] #37897
01/28/08 01:13 AM
01/28/08 01:13 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Here's another one....
One of the easiest ways to spot a McLaren Mustang ( compared to your run of the mill Mustang convertible is that the Mercedes style three window rag top tucks completely under that body hatch and can not be seen at all when you are driving with the top down.
Re: Pics? [Re: Marq] #37898
01/28/08 01:15 AM
01/28/08 01:15 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
And one more since it is not chewing up my web server's bandwidth
This features my McLaren ( front ), Cobra ( middle ) and my Ferrari hatch GTA Trans Am ( back ). I love American Muscle !
You will see a lovely and comfortable blue recycling bin in front of the garage. I used it to sit on while working on the sides of the car.
Another feature of the McLaren, compared to the standard issue Mustangs... is that they raked the windshield an additional 15 degrees to make the car look sleeker and aerodynamic. In this picture you can see the difference in the angle of the McLaren windshild compared to its brother behind it.
Re: Pics? [Re: Marq] #37899
01/28/08 01:19 AM
01/28/08 01:19 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Hmmmmm.. one more
After I put the headlights back on to the car... I took a flat black paint and highlighted the openings of the functional dual ram air gun ports to make them stand out.
Re: Pics? [Re: Marq] #37900
01/28/08 01:51 AM
01/28/08 01:51 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
And some folks would like to know how this puppy started before the roller job...
The original hood was hopeless and beyond reasonable repair. So I slapped a fiberglass dual port functional ram air on. They arrive in a white gel coat ( and that is what you see ).
I had taken the car to three body shops to get a quote on painting the poor puppy... and they all came in at $4000... ( so the car sat untouched for two years until I stumbled on this message thread and decided to give it a try ).
I was thrilled by how the car turned out and at the saving of $3750...
Re: Pics? [Re: Marq] #37901
01/28/08 01:52 AM
01/28/08 01:52 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
And here is a rear shot...
At some point the rear valance on the McLaren had been damaged and the previous owner simply slapped an LX style bumper on to the car. I replaced it with the proper rear valance which you can see in the shiny red pictures of the finished car.
I also hated the lame dual exhaust tips on the car... and replaced the exhaust from front to back with a true dual Mac system with dual chrome tips on each of the new dual pipes. Nothing sexier on a sportscan then having four exhaust tips purriiing out their musical rumble at the car behind you
Re: Pics? [Re: Marq] #37902
01/28/08 01:52 AM
01/28/08 01:52 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
And a side profile...
Yup... that is how I received it... rough, scruffy and not exactly the car you want to be seen cruising in on Friday nights... ( It was embarassingly and poorly cared for by its previous owner ).
Re: New how to paint your car on a budget with a roller #37903
01/28/08 02:16 AM
01/28/08 02:16 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Because I was painting the car in Fire Red, I was able to buy the aerosol and liquid canned paint in the same color. So for under the hood, I used the spray aerosol. For the inner lip of the fender and the hood I also sprayed with the aerosol bomb. I did all my spraying BEFORE doing the roller job on the more exposed exterior parts.
I think at some point I also touched up the inner ffender part that is attached in the engine compartment with a 1" foam paint brush.
While working in the engine compartment I covered the engine and inner fender walls and inner firewall with a sheet of plastic that I taped into position ( just to cut down on the over spray getting in the engine compartment ).
I just opened the doors and used the aerosol bomb to spray into those hard to reach places. I also spray bombed the bottom of the door panels. The spray bombing went on pretty smoothy and I ended up putting on three coats over a three day period. No additional finishing or waxing was required. It looks like it has always been there. And that was going from black to red.
Nah... I went about things the other way around. Get the piddly detail work done first. This way your roller job will not get runs or oversprays that may happen if you did the body first and the 'hard to reach areas' second.
The other advantage of getting the piddly things done first.. is that any overpray on the body can be easily worked over when you do your body sanding and body paint rolling.
In the end... the exterior body is the most important visually to you and anyone who looks upon your roller paint job. Nothing would make you cry more then to do a beautiful exterior body painting... and then foul it up with overspray or paint runs escaping from the 'hard to reach areas'.
Re: New how to paint your car on a budget with a roller [Re: lowell66dart] #37904
01/28/08 09:55 AM
01/28/08 09:55 AM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
Scroll down on this thread and you'll see the satin job on the Mach 1 by gfeighny.
https://board.moparts.org/ubbthreads/show...rue#Post3476310
BTW - you won't want to buff out your final coat of satin, as that will start to make it glossy. You'd end up with some kind of sem-gloss instead of satin.
Even though my attempt at it didn't turn out well, you can still give it a try. gfeighny proved that it can come out good, maybe I just couldn't get the technique down right. You can always change your mind later if it doesn't turn out to your liking
Re: New how to paint your car on a budget with a roller [Re: Gusteve] #37905
01/28/08 12:20 PM
01/28/08 12:20 PM
south louisiana
south louisiana
That's the cool thing about this paint, I only have $8 to lose.
Re: Pics? [Re: Marq] #37906
01/28/08 12:25 PM
01/28/08 12:25 PM
I have attached some pics to this message and the following messages. Plus a few of the 'BEFORE' pics to let you know what a basketcase this puppy was...
VERY VERY nice! Worth the wait to see the pics! I have always been a "Ford guy" (though I've also always appreciated other makes) and appreciated the additional info on your cars. Especially interesting about the windshield angle - I was unaware that this mod had been made to the McLarens. I'm currently driving a 2005 Ford Excursion diesel with a Superchips performance upgrade - it's great fun to smoke stock Mustang GT's with my big truck and still get decent fuel mileage - hehe!!
Thanks again for reposting the pics, Marq! I would have loved to see the look on the faces of the body shop guys (or gals) you received quotes from when you showed them your "home roller job!"
One of these days, when my Big X's paint job starts to fade (and we know it will) I'll have to seriously consider going this route, since I'm planning to keep the truck at least ten years and the cost to cover that much "real estate" would probably dwarf the quotes you got on the Mustangs!
Roll On!!!
Regards,
Re: New how to paint your car on a budget with a roller [Re: Marq] #37907
01/28/08 07:22 PM
01/28/08 07:22 PM
Marq: Does that mustang have 92-99 Pontiac Bonneville rims on it?
If so, were those painted with Rustoleum as well or how were they done? Or were they on the car when the PO had it?
Re: New how to paint your car on a budget with a roller #37908
01/28/08 11:59 PM
01/28/08 11:59 PM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Actually the story about the rims is kind of interesting. If you look at the BEFORE pictures of the McLaren ( when it was in its black paint job ) those are the original genuine McLaren rims.
They were custom made by ASC for the McLarens. The only problem with them is that they only had about a 1/2 lip of chrome. So there wasn't much depth or 'bling' to their appearance....
It turns out that back in 1988 the McLaren Mustangs were in competition with a rising star in the automotive history " SALEEN ".
McLarens were built for primarily appearance and touring. The Saleens were being built primarily for performance.
Well.. it turns out that in 1988 Saleen liked the look of the McLaren ASC rims. So they had their own version of the rims made... but the big difference was they had a 2 3/4 inch chrome lip on the rim - giving it more depth and bling.
Also.. the McLaren rim could accomodate up to a 225 wide tire at the most... the Saleen rim could accommodate up to a 255 wide tire...
So... imagine this. In 1988 a guy down in Florida ordered a brand new Saleen. When he received it, he immediately took those Saleen rims off and replaced them with the FIVE STAR Mustang rims ( which he thought were sexier ).
Spring forward to 1998... ten years after... and the original Saleen owner has gone through his garage and takes his stored rims out of their time capsule AND he put his UNUSED MINT 1988 Saleen rims on eBay...
I picked up the rims for the grand total of $120 for the FOUR RIMS... Unfortunately I had to pay roughly another $120 to have them packaged up safely and shipped from Florida to my home at the time in Pennsylvania.
And so goes the tale of how a brand new mint set of 1988 Saleen rims ended up on a 1988 McLaren.
And as for my 1988 McLaren rims... well I sold them almost instantly to another member of the McLaren registry for $120.
So the end result was that I was only out of pocket by $100 for the Saleen rims.
Ok... me bad. A 'true' McLaren fanatic would want to have kept the car all stock, with matching numbers and original parts. BUT I am a 'driver' and I want a car that fits me and my taste. I can't afford to be a purist or elitist ( heck a roller paint job alone would be enough to send McLaren purist running for a stiff drink of Scotch ).
Those Pontiac rims in your picture are 'sort of like' the McLaren rim ( with less then 1/2 inch of lip on them ).
It is funny that the Pontiac rim in your picture is almost the same style that I have on my GTA TransAM. But my GTA rims also have about a 2 1/2 inch deep chrome lip. From what I gather they only made the rims on my car for one model year.
Re: New how to paint your car on a budget with a roller [Re: Marq] #37909
01/29/08 12:04 PM
01/29/08 12:04 PM
FarDarter Offline
FarDarter  Offline
I just wanted to show a quick project I'm working on in addition to my Dart. The lead seam in the roof of my GTO needed some attention so I stripped the paint off and got busy. Afterwards I decided to try to match the color with Rustoleum. Here are my results. I love this stuff! I even put it on with a foam brush.
[image][/image]
Re: New Paint job on a budget thread. #37910
01/29/08 06:51 PM
01/29/08 06:51 PM
Beaverton. Oregon
cyberized Offline
cyberized  Offline
Beaverton. Oregon
Someone posted a photo of a sail boat painted with Flag Blue and you would swear that it must be BLACK. I want to see Sapphire Blue!
Re: New Paint job on a budget thread. [Re: cyberized] #37911
01/30/08 02:47 AM
01/30/08 02:47 AM
This is my first post. I've enjoyed all the info that everyone has posted. I joined just to follow this thread. I don't own any Mopar products, but my interests are in Jeep Cherokees.
Has anyone thought of using a palm sander or some other vibration device (not your old lady's) to vibtrate the bubbles out or help level the paint?
Also, came across this:
http://www.bluewatermarinepaint.com/
They use to own Interlux Yacht Finishes that makes Brightside. They were the private label for West Marine and several other companies, according to a PDF I downloaded. They also sell gallons of single stage enamel truck paint for reasonable price. No shipping or sale taxes, but they do charge a $19.95 handeling fee on the entire order.
Chris
AKA: BigBlue
Re: New Paint job on a budget thread. #37912
01/30/08 03:53 AM
01/30/08 03:53 AM
Marq:
Very interesting story on the rims. I noticed the newer gold rims were different than the black ones, but the black ones looked like bonnie rims. The funny part is that they would fit the Mustang hubs just fine too :P Lucky you got them back in 1998 or you would have had a heck of a time getting them now considering how much traffic eBay gets these days.
Personally, I would have kept the original McLaren rims in storage just to be able to swap the car back to stock if the need or desire ever arose. The Saleen rims do look better (although I like the black color better) with the wider lip. I'm a fan of modding cars to suit my desires, but I also don't want to hack it up so much that I can't put it back to factory stock for the sake of collectibility.
Its funny that you mention the TA rims... that one year of crosslaces happen to look almost identical to Buick GNX rims and people with Grand Nationals use the TA rims to make a GNX clone. Look 'em up on Ebay, they go for quite the pretty penny.
The Bonnie crosslace rims are used by later-era Pontiac and Buick guys (after the lug pattern was changed) to hint to GNX rims too. The lug pattern of actual GN/Regal rims is different so we have to use the Bonnie rims for our lug pattern. When painted black, Bonnie crosslace rims actually look pretty darn nice: http://www.cardomain.com/ride/2556893/7
Lucky for us, the Bonnie crosslace rims were used from 92-99, were the lightest alloy rims available during that time, and they're easy to find for pretty cheap.
Back on topic, I'm in the works of getting a set and plan on painting them with rustoleum this spring, so thats why I was asking if you happened to paint a set yourself :P
I think I'm going to use aircraft stripper to get the old clearcoat off, and then just spray bomb the crosslace section... I don't see much point in trying to roll the laces.
Re: New Paint job on a budget thread. #37913
01/30/08 10:21 AM
01/30/08 10:21 AM
Its been a while. finally got another break in the weather. I work nights and scheduled to leave at 6am. So far for the past couple of days its been a little below freezing. So everytime i got out of work, all cars have a sheet of ice on em'. I wasnt about to go outside and get frost bite on my hands trying to take the ice off
So this morning, it was perfect. nice 60 degrees.
I believe this is my 5th coat. After using 800g i almost just almost went back to original paint. I didnt get any pictures right after sanding. I always thought from the beginning I thinned the paint too much. so i added a little more paint to the mix. i laid it out and came out pretty good. No runs, thin but not too thin. I can barely see the original paint.
(Took crappy pics - wrong settings on camera )
As Borat would say, "wow wow wee"
almost full coverage (cant see original paint on crappy shot)
drying up pretty quick
Nice reflections. Hopefully a couple more coats and ill be set to move on!
