OD trans rear seals #378789
07/18/09 11:08 AM
07/18/09 11:08 AM
Conway, SC
T2R9 Offline OP
T2R9  Offline OP
Conway, SC
I have a 76 Duster with the original 4-speed OD trans in it. I cannot find a output seal any where for this. The one Brewers lists has a 1.625 id and my yoke is 1.695. Also the od where it fits into the tail shaft is 2.50 and is just a little too small. Its a 30 spline output shaft.
All the local stores carry one with small dimensions. Anyone seen this? If so what seal did you use?
Re: OD trans rear seals [Re: T2R9] #378790
07/18/09 11:11 AM
07/18/09 11:11 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I used a National #7300S seal from Advance Auto on my O.D. A-833s.
Same specs as yours.
http://shop.advanceautoparts.com/webapp/...%7CGRP60019____
The seal pictured in the link above is not the actual seal you get. I just looked at my A-833 and verfied the part number stamped on the flange.
Re: OD trans rear seals [Re: T2R9] #378791
07/18/09 11:14 AM
07/18/09 11:14 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
alot of the A body OD's I have seen use the 904 sized output , the first year or 2 they were 727 sized , get a seal for a 727 since you have a 30 spline output , that's 727 ...
Re: OD trans rear seals [Re: JohnRR] #378792
07/18/09 11:19 AM
07/18/09 11:19 AM
Conway, SC
T2R9 Offline OP
T2R9  Offline OP
Conway, SC
Thanks guys, I do have a large yoke, I will head over to Advance right now as I am dead in the water without one.
