360/340 exhaust manifolds #378769
07/18/09 10:44 AM
07/18/09 10:44 AM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
Hi:
First of all i'm sorry for loosing this info that I had once before.I had the numbers but the manifolds were not handy.These manifolds came from a 71 360 motor in a c body.My part numbers are as follows...#3418823 and 3418621. are they hipo manifolds?What will they fit? Can I use just the passenger side to any benifit,I know the drivers side will not work on my car (early A-body)that has the 273 manifolds still on it,or will this cause an imbalance in the exhaust flow,
or some improvement over the 273's
mike
Re: 360/340 exhaust manifolds [Re: mikepar] #378770
07/18/09 11:33 AM
07/18/09 11:33 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
71 360 manifolds were a completley different animal than the HP 340 manifolds.
Re: 360/340 exhaust manifolds [Re: MoparforLife] #378771
07/18/09 02:31 PM
07/18/09 02:31 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No, not exactly true, the 3418623 RH side and 3418621 LH were the same for (some) 71 360 C-body's and all 71 340 B&E body cars.
The 71 A-body 340 used 2863553 on the LH side and 3418623 on the RH side.
The castings you listed above (351) are unique to C-body but I don't think 3418823 is a good number, I'll bet it's 3418623?.
Re: 360/340 exhaust manifolds [Re: ScottSmith_Harms] #378772
07/18/09 03:15 PM
07/18/09 03:15 PM
Upper Midwest
Upper Midwest
there is a demand for the left side 71 & older 340 manifolds for racers that have to run cast manifolds, (wish I would have more fo them) where you can't give away left 360 manifold. Here are some of the 340 manifolds. compare for yourself.
http://motors.shop.ebay.com/items/?_nkw=...r&_osacat=0
