? for setting preload on hydraulic roller lifters. #378561
07/18/09 02:24 AM
07/18/09 02:24 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
I have a set of comp roller hydraulic lifters. The spec sheet calls for .030 to .050 preload. I have comp roller rockers that have 3/8 x 24 adjustment screws. 24 threads per inch is .041 inches per thread. 1" divided by 24 = .041.
Once I get the freeplay out of the rockers, can I just make 1 full turn to get approximately .041 inches of preload?
Chris from New Jersey
Re: ? for setting preload on hydraulic roller lifters. [Re: fig426] #378562
07/18/09 05:04 AM
07/18/09 05:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Yes.
Re: ? for setting preload on hydraulic roller lifters. [Re: 451Mopar] #378563
07/18/09 05:12 AM
07/18/09 05:12 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If your on the base circle and you want that much preload.
Re: ? for setting preload on hydraulic roller lifters. [Re: goldmember] #378564
07/18/09 07:16 AM
07/18/09 07:16 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Is that too much or should I go for a bit less?
Re: ? for setting preload on hydraulic roller lifters. [Re: fig426] #378565
07/18/09 08:08 AM
07/18/09 08:08 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We had crane hyd roller lifters in a old LA rig , I found with less preload we turned more rpm, we ended up going O lash + .002 preload with best results , you need the lifters with the C clip in the top and this was race only not street, We gained around 300 rpm with power min.
Re: ? for setting preload on hydraulic roller lifters. [Re: emarine01] #378566
07/18/09 06:41 PM
07/18/09 06:41 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
The lifters have the c-clips. The car does see some street use but primarily track time. Any suggestions or stay with comp's recommendation of .030 to.050?
Re: ? for setting preload on hydraulic roller lifters. [Re: fig426] #378567
07/18/09 06:53 PM
07/18/09 06:53 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I found with mine power fell off sharp 6500 with .025 preload, as I changed to less preload the rpm and power went up till I was just about on the clips and I gaind 300 turns with power, I ran half the season like that then went solid roller, looking back the hyd cam with little preload ran better than the solid roller that was a little more lift and duration
Re: ? for setting preload on hydraulic roller lifters. [Re: fig426] #378568
07/18/09 09:36 PM
07/18/09 09:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I use to run hydro stuff, I zerowed em and added bet 1/8-1/4 preload.....some stocker racers actually zero em w/out any issues I know of. I never liked that much preload myself.
Re: ? for setting preload on hydraulic roller lifters. [Re: Thumperdart] #378569
07/19/09 10:29 AM
07/19/09 10:29 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I've always set them at 1/2 to 3/4 and never had an issue, I would think with variations in oil pressure, viscosicty, vlave mass and spring pressure it might be tough to get he ideal setting in every case but you can try zero plus 1/2 and then adjust up or down in 1/4 turn increments to see if there is a difference.
In the early 90's I know some guys runing 5.0 class cars used to collapse the plungers solid and run them on mild solid rollers and spin them about 7800 to stay within the "factory lifter" rules.
WIZE
In Car:
Re: ? for setting preload on hydraulic roller lifters. [Re: Streetwize] #378570
07/19/09 01:55 PM
07/19/09 01:55 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Ok just so happens I was in the process of setting my Hydraulic roller on the 341....I'm gonna Almost try Mr Emarine's setting of 1/8thand see how it goes...I gotta pull the VC's again anyway to re-torque the heads so I'll see how it goes with less pre-load.
WIZE
In Car:
Re: ? for setting preload on hydraulic roller lifters. [Re: fig426] #378571
07/19/09 02:03 PM
07/19/09 02:03 PM
I built a street hemi motor last year with Comp Cams ydraulic roller lifters, I usually set the hydraulics up with 1/4 to 1/2 turn preload cold and reajust after the cam is broken in with warmed up oil. That motor wanted 1 to 1.5 full turns of prelaod to make the lifters quiet Making them quiet down did not affect the idle or the high rpm rev range, I did send one set back after adjusting them like Comps instruction said and still having a lot of lifter-rocker arm noise, that set sounded like a old SB Chevy .030 .030 Duntov solid cam and lifters Play with the adjsutments hot a until you like it
Re: ? for setting preload on hydraulic roller lifters. [Re: Cab_Burge] #378572
07/19/09 03:38 PM
07/19/09 03:38 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Don't worry about the idle noise it goes away with rpm , and I did say more power not less noise The only down side I found with the hyd roller was with a tall hyd roller lifter with little or no preload and a W style offset intake rocker the push rod angle was way out there
Re: ? for setting preload on hydraulic roller lifters. [Re: emarine01] #378573
07/23/09 08:34 AM
07/23/09 08:34 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Where does the noise come from? The rocker hitting the valve? The pushrod hitting the rocker? The pushrod hitting the plunger? The plunger hitting the C clip? Or the lifter hitting the cam? Either way, wouldn't any of them be bad for the rollers on the lifter or the rollers on the rockers? Or am I just way off here?
Re: ? for setting preload on hydraulic roller lifters. [Re: emarine01] #378574
07/23/09 09:57 AM
07/23/09 09:57 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I set my Comps to 1/2 turn on my 372 small block 5 years ago. Pulls clean to 6800. Never have had to touch them.
Doug
Re: ? for setting preload on hydraulic roller lifters. [Re: dvw] #378575
07/23/09 10:02 AM
07/23/09 10:02 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Speaking of HYD cams, a friend of mine just ran his brand new small block with a Comp Cams Hyd flat tappet cam and wiped 3 lobes. As far as I know he did everything right, adjusted the rockers with the right preload, plenty of break in lube, 20 minute break in period, no problems at first, then started losing power, found a cracked lifter and 3 wiped lobes. What could be the cause of this? I've heard of solid cams having problems lately with the zinc issues but never a hyd. cam?
Re: ? for setting preload on hydraulic roller lifters. [Re: ScottSmith_Harms] #378576
07/23/09 02:10 PM
07/23/09 02:10 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Scott,
Hydraulic flat tappets have had major issues wiping cams.
Was the rpm's varied during break in ? Did
the lifters fit good so they could rotate with
ease ? Their are a number of things that can cause
this. Their were problems with incorrect lifter face finish
and crown early on, crown of the lifter face helps with
rotation and that could also be one of the causes. I've always
used 0 lash and a 1/2 turn to set preload.
Also to add more about preload, the less preload
you use the more power it frees up due to the
amount of HP it takes to turn the motor over
with hydraulics. Less preload frees the motor
up.
logan426
Re: ? for setting preload on hydraulic roller lifters. [Re: MLR426] #378577
07/23/09 03:08 PM
07/23/09 03:08 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
On my old hyd roller with .001 to .002 preload , I thought it stopped lifter pump up with a HV oil pump @ high rpm by stopping the plunger before valve float, but anyhow it freed 300 turns however it did it
Re: ? for setting preload on hydraulic roller lifters. [Re: MLR426] #378578
07/23/09 06:20 PM
07/23/09 06:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Scott,
I've only heard of these problems with solid lifter cams, not hydraulics?
Re: ? for setting preload on hydraulic roller lifters. [Re: ScottSmith_Harms] #378579
07/23/09 06:28 PM
07/23/09 06:28 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Scott,
Most hyd cams I spec ed out don't run the spring pressures that solids have , I think its the springs that wire out cams
Re: ? for setting preload on hydraulic roller lifters. [Re: emarine01] #378580
07/23/09 08:44 PM
07/23/09 08:44 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
So I should say heck with a "measured" preload and just adjust the noise out of them when hot?
