69 Coronet/Super Bee #378058
07/17/09 11:18 AM
07/17/09 11:18 AM
SD800 Offline OP
SD800  Offline OP
Does the rear window require a gasket to install the window or does it use the rubber glue?
You'll have plenty of time to sleep when your dead, let's go
Re: 69 Coronet/Super Bee [Re: SD800] #378059
07/17/09 12:06 PM
07/17/09 12:06 PM
portland or
new bee Offline
Richard Cranium
new bee  Offline
Richard Cranium
portland or
There is no rear window gasket. What you want is 5/16 butyl (sp?) tape. This will raise the glass to a good height so you can get the trim on easier.
I am pretty sure the correct thickness is 5/16 - can another member confirm?
*1969 383 4sp. Super Bee
*1966 Alfa Romeo Giulia Sprint GT
*1965 Porsche 356C
*2004 VW Passat Wagon
*2004 Mini Cooper S
*1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: 69 Coronet/Super Bee [Re: SD800] #378060
07/17/09 09:25 PM
07/17/09 09:25 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
The rear window actually uses black urethane and you can have a local 'glass guy' do it pretty cheap. Just tell him how thick you want him to put it on. I've seen 'em lay 2 beads of urethane (one on top of the other) to get the proper height/thickness; especially on trucks and SUV's
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: 69 Coronet/Super Bee [Re: BFASTER] #378061
07/17/09 11:48 PM
07/17/09 11:48 PM
portland or
new bee Offline
Richard Cranium
new bee  Offline
Richard Cranium
portland or
we tried urethane and the tape worked better
*1965 Porsche 356C
*2004 Mini Cooper S
Re: 69 Coronet/Super Bee [Re: SD800] #378062
07/20/09 12:34 AM
07/20/09 12:34 AM
vancouver wa
mad car disease Offline
vancouver wa
5/16" wide ribbon seal (also called butyl tape) is the way that the factory did it. Black urethane is what newer cars use and what most glass guys carry in stock. They say they can make it high enough for the trim to sit correct but I yet to see that happen. They also try to tell you that the urethane is better and your window won't pop out....LOL... my 30+ year old car still has it's glass and the Butyl tape is still holding fine. Good luck...
Re: 69 Coronet/Super Bee [Re: mad car disease] #378063
07/21/09 04:14 PM
07/21/09 04:14 PM
SD800 Offline OP
SD800  Offline OP
Thanks guys,
Re: 69 Coronet/Super Bee [Re: SD800] #378064
07/21/09 05:24 PM
07/21/09 05:24 PM
rochester michigan, oakland co...
drmonday Offline
drmonday  Offline
I first used butyl tape on my coronet back glass and it leaked like a sieve. Cut it back out and used ureathane and it fits perfect with no leaks.
