Re: chemically bond the outer wheel houses to the quarter ?
[Re: RobR]
#378041
07/17/09 12:19 PM
07/17/09 12:19 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
been a couple of threads on this over the years. apparently when glueing on panels, the joint is stronger than the rest of the metal itself. tests have been done where 2 panels are glued together, then pulled apart until failure, and the failure is always somewhere OTHER than the glued/bonded joint.
**Photobucket sucks**
[Re: RobR]
#378043
07/17/09 01:20 PM
07/17/09 01:20 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Doors are glued on to give you an idea of how strong the bonding agents are..
The doors on my daily driver (late model Camaro) are glued together, but they are not metal..
Late model Aussie Ford Falcons have the entire firewalls glued in as well..
[Re: OzHemi]
#378044
07/17/09 01:26 PM
07/17/09 01:26 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I can see the strength advantages but what I am not sure of is how it does over time. Can water seep in and rust between the glue and the metal? What is the required prep?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#378045
07/17/09 01:35 PM
07/17/09 01:35 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Actually it is easier for water to get around and in between welds
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Dougsmopars]
#378050
07/17/09 05:58 PM
07/17/09 05:58 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
Have seen it fail. 3m Rep when 8115 1st came out said yeah weld a panel on then run this over the ground weld grind it smooth and plastic over that. Complete water tight/proof!. WRONG 70 chevelle 396 car we did it on showed the weld seam 3 months after it went out the door. Black car too! 3M warrantied it though. I have seen it done on the wheel well. Been there done that. The thing I feel in South Dakota is that the temp changes so much that it make the glue brittle and breaks. We did a 87 chevy truck that we did patchs on the box sides. Seen it and the panels are loose. Things sits outside all year long. When we put it on we sandblasted the inner wheel house,ground the new patch where the glue would be bound,smoothed glue over both panels to cover the bare metal then came back with the glue bead. Mounted the panels w/ clamps over night. Just the way they say to do it. Didn't save that one. I do think that the ones w/the beads in the glue that helps so it wont squish out completely. I kind of feel that could have been the problem on the truck. Customer isn't worried about it though he said hey I got 7+ years extra out of the truck. Just sucks to see it happen. In case you haven't quessed it I really don't like it.
Good luck
Contact Me about AMD Prices
