SB's with Scott Brown Cam: Idle Vacuum?
#377955
07/17/09 07:36 AM
07/17/09 07:36 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am just curious what you other SB guys/gals are getting for idle vacuum numbers with your 226/238 cams. I am currently pulling 15"hg at 975rpms in N and 11" to 11-1/2"hg in D at 825-850rpms (moderate lope) and I just wanted to see if I was in the ballpark. Note: If I turn up the in gear idle to 900rpms, then the vacuum goes up to 12"hg with a mild exhaust note. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: SB's with Scott Brown Cam: Idle Vacuum?
[Re: YO7_A66]
#377956
07/17/09 08:31 AM
07/17/09 08:31 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
sounds about what I'd expect...
[Re: YO7_A66]
#377957
07/17/09 10:13 AM
07/17/09 10:13 AM
Posts: 1,261 ILL
mark7171
ILL
Most people with cams like that set there idles around 950-1krpm . If its street driven i'd set the choke cold idle to 1800rpm to get the lifters pumped up with oil nice and fast.
if your after a lower idle mill that thumps, you will need more timming 22+ at idle.
--disreguard, all my cars have been manual trans.
A auto matic trans is hard to get it to shift right on its own. Driven hotrods need manual bodies, because all the downshifts/upshifts are screwed.
[Re: mark7171]
#377958
07/17/09 10:22 AM
07/17/09 10:22 AM
YO7_A66
Indiana
Thanks Patrick. Mark, I run 24 degrees of initial timing for your reference. ""good now get it right."" What does this mean? ""A auto matic trans is hard to get it to shift right on its own. Driven hotrods need manual bodies, because all the downshifts/upshifts are screwed."" Then you need to tune your auto tranny. The shift points can be made to just about what ever you want with aftermarket governors and testing different 1-2 and 2-3 shift springs. By the way, what does this have to do with my vacuum question?
[Re: mark7171]
#377960
07/17/09 10:55 AM
07/17/09 10:55 AM
YO7_A66
Indiana
24 initial and 34 total. I run a mini starter so I have had no starting issues in three years.
""You probably heard the engine come into tune. It is a valuable diagnosis tool.""
Do you mean when I turned up the idle and the exhaust smoothed out? If so I had to turn down the idle to keep the N idle rpms low enough to keep the engine from "running on" during shut down. It does not like N idle to be above 1050rpms or it will run on. Now I have the N idle at 975rpms and it has no shut down issues and the 825/850rpm in gear idle is very smooth. This is the lowest in gear idle that I have had with this cam and the "in gear" vacuum reading only fluctuates within 1/2 of an hg. Thanks for the response.
[Re: YO7_A66]
#377961
07/17/09 11:10 AM
07/17/09 11:10 AM
Posts: 1,261 ILL
mark7171
ILL
Run on from a shut off igition ? That would be timing. Its in its curve at 1050rpm ? causing reversion.
a carb out of tune should not cause a desisel.
24 initail is stressfull on the starter, flywheel gear ring, over taxes the battery to crank, and even stresses the crank.
try running a vacuum advance distributor. I think the HEi mopar distributor is $37.99 at autozone.
[Re: mark7171]
#377962
07/17/09 11:33 AM
07/17/09 11:33 AM
patrick
Grand Haven, MI
for reference, my 360, with a stock long block that's rerung, ~7.8:1 actual compression, with a comp XE262 (262/270, 218/224 at .050, 110LSA installed at 106) is set up with 18-20 degrees initial, 36-38 degrees total mechanical advance, and idles at 950RPM in neutral with 17-18" vaccuum, and drops to 820-850 in gear and ~13" vaccuum, and 750 RPM and ~11" in gear with the A/C on.
[Re: mark7171]
#377963
07/17/09 11:35 AM
07/17/09 11:35 AM
YO7_A66
Indiana
I am running a FBO ignition system and I am very pleased with it. I can't wait for Don to bring out his ballast free coil which should be ready any week now. Thank you for your responses Mark and I will keep that distributor in mind.
[Re: patrick]
#377964
07/17/09 11:40 AM
07/17/09 11:40 AM
Posts: 1,261 ILL
mark7171
ILL
Patrick, if he was deiseling that means not enough timming.
At shutdown the engine stops pulling more fuel from the carb. Fuel that is left there, because it didnt have time to burn. He needs more timing provifded from a vacuum cam.
not pushing, best of luck.
FBo is great.
[Re: mark7171]
#377965
07/17/09 11:48 AM
07/17/09 11:48 AM
patrick
Grand Haven, MI
I was giving just a reference for vacuum levels based on my motor with a slightly smaller cam, but probably lower compression, if he has H116CP's or KB107's. more compression will help with idle vacuum as well.
dieseling/run on problems I've had are usually caused more by an overly rich idle, leaving extra/unburnt fuel in the chamber.
[Re: patrick]
#377966
07/17/09 11:51 AM
07/17/09 11:51 AM
Posts: 1,261 ILL
mark7171
ILL
When you rerung it, why no head shave ? could have went a cost effective .060" off the heads and taken back a point of compression. 8.8 will do some movin'.
[Re: mark7171]
#377967
07/17/09 01:05 PM
07/17/09 01:05 PM
patrick
Grand Haven, MI
because I was cheap (:
I could've also spent the money on thin MP head gaskets instead of using the .054" thick ones in the fel-pro engine gasket set....that woulda gotten me up to about 8.2. the engine runs real hard for what it is, though, and does it best on 87 octane.
